2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.16-win64 #244
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 11 Dec 2018 08:51:28 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/244/display/redirect>
Started by upstream project "epics-base-3.16" build number 241
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-1 (win64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.16-win64/ws/>
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:888)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1155)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
	at hudson.scm.SCM.checkout(SCM.java:504)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1810)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: fatal: The remote end hung up unexpectedly
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1735)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:420)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
	at hudson.remoting.UserRequest.perform(UserRequest.java:207)
	at hudson.remoting.UserRequest.perform(UserRequest.java:53)
	at hudson.remoting.Request$2.run(Request.java:358)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-1
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserResponse.retrieve(UserRequest.java:389)
		at hudson.remoting.Channel.call(Channel.java:955)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
		at sun.reflect.GeneratedMethodAccessor625.invoke(Unknown Source)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
		at com.sun.proxy.$Proxy104.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:886)
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : epics-base-3.16-win64 #245 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #80 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.16-cyg64 #244 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-win64s-test #200 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.16-win64 #245 APS Jenkins via Core-talk
ANJ, 11 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
