What's your motivation to go from Trusty to Xenial? Do you intend to drop support for gcc 4.x?
Note: You can always install newer gcc versions on Travis' Trusty VMs [1], but (AFAIK) there's no documented safe way to downgrade gcc on Xenial.
Cheers, ~Ralph
On Thu, 13 Dec 2018 at 18:31, Johnson, Andrew N. via Core-talk < [email protected]> wrote: For information:
Travis now supports Ubuntu Xenial 16.04 (epics-base currently builds on
trusty)
https://docs.travis-ci.com/user/reference/xenial/
The "sudo: false" setting in a .travis.yml file now has no effect and
should be removed; all Travis builds since December 7th have taken place
in a VM environment.
I would play around with these but I suspect Ralph would prefer that I
work on the 7.0.2 final release in time for his up-coming deadline, so
someone else could try out making these changes if they feel so inclined
and know how to use Travis...
- Andrew
- Travis-CI Updates Johnson, Andrew N. via Core-talk
Jenkins build is back to normal : epics-7.0-windows » STATIC,win64 #85 APS Jenkins via Core-talk
Precision and formatting - again Timo Korhonen via Core-talk
<2018>
2025
2026
<2018>
2025
2026
ANJ, 14 Dec 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
