2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Working on the 7.0.2 final release
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: "Rivers, Mark L." <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Tue, 18 Dec 2018 17:53:40 +0000
Hi Mark,
On 12/18/18 11:35 AM, Mark Rivers wrote:
> make[2]: Entering directory `/usr/local/epics-devel/base-7.0.2/modules/libcom'
> configure/CONFIG:33: /usr/local/epics-devel/base-7.0.1/configure/CONFIG: No such file or directory
> configure/RULES_TOP:2: /usr/local/epics-devel/base-7.0.1/configure/RULES_TOP: No such file or directory
> make[2]: *** No rule to make target `/usr/local/epics-devel/base-7.0.1/configure/RULES_TOP'.  Stop.
> Why is it looking for base-7.0.1 rather than base-7.0.2?  The environment variable EPICS_BASE is not set.
We build a RELEASE.<host-arch>.local file in the modules directory which
contains the full path to EPICS_BASE for the modules to use, and in your
case it still contains the old path. You should just be able to delete
those files for all your host architectures and they will be recreated
when you next run make on that arch.
As to your earlier question about the submodules, in the parent module I
think you just run
  git submodule update
which may check them out also in the detached state, although that
doesn't really matter. You should be able to replicate this output though:
> tux% git submodule status 41d56fdf89a09617f2d5fe726fa0ecb579ca551f
> modules/normativeTypes (5.2.1)
> 5e793422198d4223a03164787cacbfb6cf9575fc modules/pvAccess (6.1.0)
> d776f6eaf03c058597c05b3308636d95223b6c6e modules/pvData (7.1.0)
> 07a951c3a2bd3e95b1de24e3224e310225e3e45a modules/pvDatabase (4.4.0)
> a245adb5cfc9b4a0b0d04b630032963ecc3410d0 modules/pva2pva (1.1.0)
> b1c101578bea3610f777a1f51229eb2967dc89f4 modules/pvaClient (4.4.0)
HTH,
- Andrew
Re: Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Prev: RE: Working on the 7.0.2 final release Mark Rivers via Core-talk
Next: Re: Working on the 7.0.2 final release Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Dec 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
