Subject: |
Build failed in Jenkins: epics-base-3.15-sol #174 |
APS Jenkins via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 26 Dec 2018 07:15:04 -0600 (CST) |
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/174/display/redirect>
Started by upstream project "epics-base-3.15" build number 409
originally caused by:
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on sol-hera (sol-sparc) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-sol/ws/>
> /local/usr/bin/git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> /local/usr/bin/git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> /local/usr/bin/git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> /local/usr/bin/git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Timeout after 10 minutes
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:888)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1155)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1810)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
Caused by: hudson.plugins.git.GitException: Command "/local/usr/bin/git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 15:
stdout:
stderr: remote: Counting objects: 1 remote: Counting objects: 7 remote: Counting objects: 11 remote: Counting objects: 12 remote: Counting objects: 13 remote: Counting objects: 14 remote: Counting objects: 23 remote: Counting objects: 24 remote: Counting objects: 26 remote: Counting objects: 27 remote: Counting objects: 29 remote: Counting objects: 33 remote: Counting objects: 37 remote: Counting objects: 43 remote: Counting objects: 44 remote: Counting objects: 47 remote: Counting objects: 49 remote: Counting objects: 50 remote: Counting objects: 52 remote: Counting objects: 54 remote: Counting objects: 56 remote: Counting objects: 57 remote: Counting objects: 58 remote: Counting objects: 61 remote: Counting objects: 62 remote: Counting objects: 64 remote: Counting objects: 69 remote: Counting objects: 71, done.
remote: Compressing objects: 1% (1/71) remote: Compressing objects: 2% (2/71) remote: Compressing objects: 4% (3/71) remote: Compressing objects: 5% (4/71) remote: Compressing objects: 7% (5/71) remote: Compressing objects: 8% (6/71) remote: Compressing objects: 9% (7/71) remote: Compressing objects: 11% (8/71) remote: Compressing objects: 12% (9/71) remote: Compressing objects: 14% (10/71) remote: Compressing objects: 15% (11/71) remote: Compressing objects: 16% (12/71) remote: Compressing objects: 18% (13/71) remote: Compressing objects: 19% (14/71) remote: Compressing objects: 21% (15/71) remote: Compressing objects: 22% (16/71) remote: Compressing objects: 23% (17/71) remote: Compressing objects: 25% (18/71) remote: Compressing objects: 26% (19/71) remote: Compressing objects: 28% (20/71) remote: Compressing objects: 29% (21/71) remote: Compressing objects: 30% (22/71) remote: Compressing objects: 32% (23/71) remote: Compressing objects: 33% (24/71) remote: Compressing objects: 35% (25/71) remote: Compressing objects: 36% (26/71) remote: Compressing objects: 38% (27/71) remote: Compressing objects: 39% (28/71) remote: Compressing objects: 40% (29/71) remote: Compressing objects: 42% (30/71) remote: Compressing objects: 43% (31/71) remote: Compressing objects: 45% (32/71) remote: Compressing objects: 46% (33/71) remote: Compressing objects: 47% (34/71) remote: Compressing objects: 49% (35/71) remote: Compressing objects: 50% (36/71) remote: Compressing objects: 52% (37/71) remote: Compressing objects: 53% (38/71) remote: Compressing objects: 54% (39/71) remote: Compressing objects: 56% (40/71) remote: Compressing objects: 57% (41/71) remote: Compressing objects: 59% (42/71) remote: Compressing objects: 60% (43/71) remote: Compressing objects: 61% (44/71) remote: Compressing objects: 63% (45/71) remote: Compressing objects: 64% (46/71) remote: Compressing objects: 66% (47/71) remote: Compressing objects: 67% (48/71) remote: Compressing objects: 69% (49/71) remote: Compressing objects: 70% (50/71) remote: Compressing objects: 71% (51/71) remote: Compressing objects: 73% (52/71) remote: Compressing objects: 74% (53/71) remote: Compressing objects: 76% (54/71) remote: Compressing objects: 77% (55/71) remote: Compressing objects: 78% (56/71) remote: Compressing objects: 80% (57/71) remote: Compressing objects: 81% (58/71) remote: Compressing objects: 83% (59/71) remote: Compressing objects: 84% (60/71) remote: Compressing objects: 85% (61/71) remote: Compressing objects: 87% (62/71) remote: Compressing objects: 88% (63/71) remote: Compressing objects: 90% (64/71) remote: Compressing objects: 91% (65/71) remote: Compressing objects: 92% (66/71) remote: Compressing objects: 94% (67/71) remote: Compressing objects: 95% (68/71) remote: Compressing objects: 97% (69/71) remote: Compressing objects: 98% (70/71) remote: Compressing objects: 100% (71/71) remote: Compressing objects: 100% (71/71), done.
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1735)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:420)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:153)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$1.call(RemoteGitImpl.java:146)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to sol-hera
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:955)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor625.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy104.execute(Unknown Source)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:886)
[WARNINGS] Skipping publisher since build result is FAILURE
- Jenkins build is back to normal : epics-base-3.15-sol #175 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.15-linux32 #376 APS Jenkins via Core-talk
Jenkins build is back to normal : epics-base-3.15 #410 APS Jenkins via Core-talk
<2018>
2025
2026
Jenkins build is back to normal : epics-base-3.15-linux32 #377 APS Jenkins via Core-talk
<2018>
2025
2026
