2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-win32-test #205
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 27 Feb 2019 11:50:13 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32-test/205/display/redirect>
Started by upstream project "epics-base-3.15-win32" build number 381
originally caused by:
 Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win32-2 (win32-x86) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32-test/ws/>
[epics-base-3.15-win32] $ sh.bat C:\Users\jenkins\AppData\Local\Temp\jenkins8149959629597851205.sh
The system cannot find the file specified
FATAL: command execution failed
java.io.IOException: CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessImpl.create(Native Method)
	at java.lang.ProcessImpl.<init>(Unknown Source)
	at java.lang.ProcessImpl.start(Unknown Source)
Also:   hudson.remoting.Channel$CallSiteStackTrace: Remote call to win32-2
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
		at hudson.remoting.Channel.call(Channel.java:955)
		at hudson.Launcher$RemoteLauncher.launch(Launcher.java:1059)
		at hudson.plugins.cygpath.CygpathLauncherDecorator$1.launch(CygpathLauncherDecorator.java:66)
		at hudson.Launcher$ProcStarter.start(Launcher.java:455)
		at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:109)
		at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:66)
		at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
		at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:744)
		at hudson.model.Build$BuildExecution.build(Build.java:206)
		at hudson.model.Build$BuildExecution.doRun(Build.java:163)
		at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:504)
		at hudson.model.Run.execute(Run.java:1810)
		at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
		at hudson.model.ResourceController.execute(ResourceController.java:97)
		at hudson.model.Executor.run(Executor.java:429)
Caused: java.io.IOException: Cannot run program "sh.bat" (in directory "C:\jenkins\win32-2\workspace\epics-base-3.15-win32"): CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessBuilder.start(Unknown Source)
	at hudson.Proc$LocalProc.<init>(Proc.java:249)
	at hudson.Proc$LocalProc.<init>(Proc.java:218)
	at hudson.Launcher$LocalLauncher.launch(Launcher.java:936)
	at hudson.Launcher$RemoteLaunchCallable.call(Launcher.java:1313)
	at hudson.Launcher$RemoteLaunchCallable.call(Launcher.java:1266)
	at hudson.remoting.UserRequest.perform(UserRequest.java:212)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
Build step 'Execute shell' marked build as failure
Jenkins build is back to normal : epics-base-3.15-win32-test #206 APS Jenkins via Core-talk
Prev: Jenkins build became unstable: epics-7.0 » linux32 #96 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-win32s-test #215 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to stable : epics-7.0 » linux32 #97 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-win32-test #206 APS Jenkins via Core-talk
ANJ, 07 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
