Subject: |
Build failed in Jenkins: epics-base-3.15-win64 #402 |
APS Jenkins via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 27 Feb 2019 12:57:26 -0600 (CST) |
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/402/display/redirect>
Started by user Andrew Johnson
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/ws/>
No credentials specified
> C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
> C:/Program Files/Git/cmd/git.exe rev-parse "origin/3.15^{commit}" # timeout=10
Checking out Revision 736075daf6507c847c7ea90b2cf21342fecc832e (origin/3.15)
> C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files/Git/cmd/git.exe checkout -f 736075daf6507c847c7ea90b2cf21342fecc832e
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-2
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:955)
at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:283)
at com.sun.proxy.$Proxy100.withRepository(Unknown Source)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl.withRepository(RemoteGitImpl.java:235)
at hudson.plugins.git.GitSCM.printCommitMessageToLog(GitSCM.java:1277)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1250)
at hudson.scm.SCM.checkout(SCM.java:504)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1810)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:429)
org.eclipse.jgit.errors.MissingObjectException: Missing unknown 736075daf6507c847c7ea90b2cf21342fecc832e
at org.eclipse.jgit.internal.storage.file.WindowCursor.open(WindowCursor.java:158)
at org.eclipse.jgit.lib.ObjectReader.open(ObjectReader.java:227)
at org.eclipse.jgit.revwalk.RevWalk.parseAny(RevWalk.java:859)
at org.eclipse.jgit.revwalk.RevWalk.parseCommit(RevWalk.java:772)
at hudson.plugins.git.util.RevCommitRepositoryCallback.invoke(RevCommitRepositoryCallback.java:25)
at hudson.plugins.git.util.RevCommitRepositoryCallback.invoke(RevCommitRepositoryCallback.java:13)
at org.jenkinsci.plugins.gitclient.AbstractGitAPIImpl.withRepository(AbstractGitAPIImpl.java:29)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.withRepository(CliGitAPIImpl.java:72)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: epics-base-3.15-win64 #403 APS Jenkins via Core-talk
Jenkins build is back to normal : epics-base-3.15-win32s-test #216 APS Jenkins via Core-talk
<2019>
2025
2026
<2019>
2025
2026
