2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: travis builds by accident ?
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Tue, 12 Mar 2019 21:42:50 +0000
Hello Heinz,
On 3/12/19 3:29 PM, Heinz Junkes via Core-talk wrote:
> https://travis-ci.org/epics-base/epics-base/builds/505354289
> RTEMS 4.9 and 4.10 worked on this build, but the clang build didn't work yet.
> But with this build https://travis-ci.org/epics-base/epics-base/builds/503202296
> the clang build worked.
> What am I doing wrong?
Nothing, some of our tests don't always pass because the test code
doesn't allow for different timings, slow CPUs etc. In the above case
the errlog test failed (unfortunately a fairly common occurrence in this
test) for the one clang build. You can click the "restart job" button to
have it re-run that job (not the "Restart Build" button which would
re-run all the jobs) and most likely it will succeed the second time; I
just did that.
- Andrew
travis builds by accident ? Heinz Junkes via Core-talk
Prev: travis builds by accident ? Heinz Junkes via Core-talk
Next: Jenkins build is unstable: epics-7.0 » linux64 #101 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 13 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
