2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-3.14 #256
From: Jenkins EPICS PSI via Core-talk <[email protected]>
To: <[email protected]>, <[email protected]>
Date: Wed, 27 Mar 2019 19:20:47 +0100
See <http://gfa-sls2-test:8080/job/EPICS-3.14/256/display/redirect>
Started by timer
Building in workspace <http://gfa-sls2-test:8080/job/EPICS-3.14/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test:8080/job/EPICS-3.14/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: remote: Counting objects: 1           remote: Counting objects: 17           remote: Counting objects: 43           remote: Counting objects: 81           remote: Counting objects: 111           remote: Counting objects: 154           remote: Counting objects: 192           remote: Counting objects: 251           remote: Counting objects: 287           remote: Counting objects: 323           remote: Counting objects: 350           remote: Counting objects: 389           remote: Counting objects: 500           remote: Counting objects: 572           remote: Counting objects: 592           remote: Counting objects: 666           remote: Counting objects: 831           remote: Counting objects: 935           remote: Counting objects: 6024           remote: Counting objects: 8731           remote: Counting objects: 16160           remote: Counting objects: 17295           remote: Counting objects: 18015           remote: Counting objects: 18494           remote: Counting objects: 18535           remote: Counting objects: 18871           remote: Counting objects: 19178           remote: Counting objects: 19368           remote: Counting objects: 19434           remote: Counting objects: 19451           remote: Counting objects: 19534           remote: Counting objects: 19621           remote: Counting objects: 20048           remote: Counting objects: 20476           remote: Counting objects: 20545           remote: Counting objects: 20725           remote: Counting objects: 21128           remote: Counting objects: 21710           remote: Counting objects: 21770           remote: Counting objects: 21847           remote: Counting objects: 21955           remote: Counting objects: 21999           remote: Counting objects: 22063           remote: Counting objects: 22279           remote: Counting objects: 22313           remote: Counting objects: 22440           remote: Counting objects: 22602           remote: Counting objects: 22735           remote: Counting objects: 22880           remote: Counting objects: 23090           remote: Counting objects: 23202           remote: Counting objects: 23362           remote: Counting objects: 23593           remote: Counting objects: 23880           remote: Counting objects: 24698           remote: Counting objects: 24720           remote: Counting objects: 24743           remote: Counting objects: 24875           remote: Counting objects: 25226           remote: Counting objects: 25499           remote: Counting objects: 26241           remote: Counting objects: 31187           remote: Counting objects: 40547           remote: Counting objects: 45623           remote: Counting objects: 45783           remote: Counting objects: 56620           remote: Counting objects: 64063           remote: Counting objects: 71218           remote: Counting objects: 72409           remote: Counting objects: 75166           remote: Counting objects: 83361           remote: Counting objects: 94890           remote: Counting objects: 101637           remote: Counting objects: 110909           remote: Counting objects: 119350, done.
remote: Compressing objects:   0% (1/34115)           remote: Compressing objects:   0% (228/34115)           fatal: The remote end hung up unexpectedly
fatal: protocol error: bad pack header
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1735)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:420)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:629)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1146)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
	at hudson.scm.SCM.checkout(SCM.java:504)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1819)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:429)
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-3.14 #257 Jenkins EPICS PSI via Core-talk
Prev: Re: Get sub field of Union Benjamin Franksen via Core-talk
Next: Re: RTEMS5 with epics-base Gedare Bloom via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Get sub field of Union Marty Kraimer via Core-talk
Next: Jenkins build is back to normal : EPICS-3.14 #257 Jenkins EPICS PSI via Core-talk
ANJ, 28 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
