2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0
From: Andrew Johnson via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Fri, 29 Mar 2019 00:15:37 -0000
Core Group mtg: Further exploration on Perl ModuleDirs files by ANJ; diff comments with fixes, but in principle this is acceptable.
Diff comments:
> diff --git a/modules/ca/src/perl/capr.pl b/modules/ca/src/perl/capr.pl
> index e551afc..17a6dd0 100644
> --- a/modules/ca/src/perl/capr.pl
> +++ b/modules/ca/src/perl/capr.pl
> @@ -10,8 +10,7 @@
>  use strict;
>  use FindBin qw($Bin);
> -use lib ($Bin, "$Bin/../../lib/perl");
> -use caModuleDirs;
> +use lib ("$Bin/../../lib/perl");
>  no lib $Bin;
Remove "no lib $Bin" in all non-template scripts where you removed $Bin from the "use lib" line.
>  use Getopt::Std;
> diff --git a/modules/ca/src/template/top/caPerlApp/caget.pl b/modules/ca/src/template/top/caPerlApp/caget.pl
> index 0d9af37..dae3a77 100644
> --- a/modules/ca/src/template/top/caPerlApp/caget.pl
> +++ b/modules/ca/src/template/top/caPerlApp/caget.pl
> @@ -4,7 +4,7 @@ use strict;
>  # This construct sets @INC to search lib/perl of all RELEASE entries
This probably breaks the template, and ANJ wants to keep the ModuleDirs stuff which is needed for this template code to work (or users have to set PERL5LIB to Base/lib/perl).
>  use _APPNAME_ModuleDirs;
>  no lib $Bin;
> diff --git a/modules/libcom/configure/CONFIG b/modules/libcom/configure/CONFIG
> deleted file mode 100644
> index 774ed25..0000000
> --- a/modules/libcom/configure/CONFIG
> +++ /dev/null
> @@ -1,44 +0,0 @@
> -# CONFIG - Load build configuration data
> -# Do not make changes to this file!
> -ifeq ($(strip $(EPICS_HOST_ARCH)),)
> -  $(warning EPICS_HOST_ARCH is not set.)
> -endif
> -# Allow user to override where the build rules come from
> -RULES = $(EPICS_BASE)
> -# RELEASE files point to other application tops
> -include $(TOP)/configure/RELEASE
> --include $(TOP)/configure/RELEASE.$(EPICS_HOST_ARCH).Common
> -ifdef T_A
> --include $(TOP)/configure/RELEASE.Common.$(T_A)
> --include $(TOP)/configure/RELEASE.$(EPICS_HOST_ARCH).$(T_A)
> -endif
> -ifeq ($(strip $(RULES)),)
> -  ifeq ($(strip $(EPICS_BASE)),)
> -    $(warning Build error: EPICS_BASE not set after including RELEASE files.)
> -  else
> -    $(warning Build error: EPICS_BASE set but RULES variable empty.)
> -  endif
> -  $(error Makefiles loaded: $(MAKEFILE_LIST))
> -  # Die before the include of $(CONFIG)/CONFIG below does
> -endif
> -BUILDING_LIBCOM = DEFINED
Conditional stuff in CONFIG_LIBCOM_MODULE needs removing that used BUILDING_LIBCOM when building stand-alone.
> -CONFIG = $(RULES)/configure
> -include $(CONFIG)/CONFIG
> -# Override the Base definition:
> -INSTALL_LOCATION = $(TOP)
> -# CONFIG_SITE files contain other build configuration settings
> -include $(TOP)/configure/CONFIG_SITE
> --include $(TOP)/configure/CONFIG_SITE.$(EPICS_HOST_ARCH).Common
> -ifdef T_A
> - -include $(TOP)/configure/CONFIG_SITE.Common.$(T_A)
> - -include $(TOP)/configure/CONFIG_SITE.$(EPICS_HOST_ARCH).$(T_A)
> -endif
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361381
Your team EPICS Core Developers is requested to review the proposed merge of ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0.
Prev: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Next: Build failed in Jenkins: epics-base-7.0-win64s-test #14 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 noreply--- via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:make-simple into epics-base:7.0 mdavidsaver via Core-talk
ANJ, 31 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
