2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Access Protocol Specification
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, Timo Korhonen <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 10 Apr 2019 07:18:23 -0700
On 4/10/19 7:03 AM, Kasemir, Kay via Core-talk wrote:
> Hello Timo,
>  > .. grumpy old man.
> Echo that, and honored to be in your company.
> I apologize for not seeing the "Resources and Support" -> "Documents" -> "pvAccess" section, that was entirely my fault.
> It does point to the same document, so at least we're consist.
I'll cop to the grumpy part.  Especially this week.
>>  ESS is eager to support a documentathon..
> Before the ITER-EPICS-meeting, will there be a pre-meeting of core developers similar to the CS-Studio devel meeting?
> I'm happy to update the size encoding description in the spec, but unclear how.
> At the same time, not sure if one sizable documentathon is the final solution.
> I understand that a specification should be somewhat fixed, but at the same time it may have a better chance of being correct when it's in an editable form.
> So use the ITER-EPICS-premeeting to copy the old spec to the new web site in a way that people with an account can then keep updating it?
Copying the content of the PVA "spec", and the NTypes doc into a wiki has long been on my TODO list.
IMO. this documentation needs to be easier to edit.  This would hopefully decrease the cost of fixing
mistakes when they are identified.  I've come across the same inconsistency wrt. size encodings.  Just
never at a time when I could/would do a mental context switch to HTML edit mode.
https://github.com/epics-base/pvDataWWW/blob/master/mainPage/pvAccess_Protocol_Specification.html
> Thanks,
> Kay
> From: Timo Korhonen <[email protected]>
> I am afraid that this is the latest version of the document. The community has accumulated a lot of documentation debt. ESS is eager to support a documentathon, we are just waiting instructions on when the community would like that to happen.
> By the way, reading the F2F core meeting notes, there was a mention about rescuing the documents from the old V4 site (epics-pvdata) and putting them on the new website. Nobody seems to have looked at the new website, under "Resources and Support" -> "Documents";  if you look carefully, there is an item called "pvAccess". Under that item you find links to a number of documents and even a downloadable "pvAccess Protocol Specification" pdf. I have also a similarly formatted Normative Types document but I was discouraged  from making pdf documents so it has not been put there.
> Or, of course, because the website structure is "wrong", nothing can be found. The structure was modelled after the APS website and reviewed by the community. Just saying. Let us do it right, then.
> Rescuing the items from the V4 site could be completed at the documentathon. Or by the numerous volunteers that will jump up to help in creating content for the new website. Next time we will give t-shirts only to people who have contributed.
Re: PV Access Protocol Specification Johnson, Andrew N. via Core-talk
PV Access Protocol Specification Kasemir, Kay via Core-talk
Re: PV Access Protocol Specification Timo Korhonen via Core-talk
Re: PV Access Protocol Specification Kasemir, Kay via Core-talk
Prev: Re: PV Access Protocol Specification Timo Korhonen via Core-talk
Next: Re: PV Access Protocol Specification Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: PV Access Protocol Specification Michael Davidsaver via Core-talk
Next: Re: PV Access Protocol Specification Johnson, Andrew N. via Core-talk
ANJ, 10 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
