All, I found a single-header-file tap listener that makes Google Test (gtest) executables spit out TAP, so that Google Test can be used inside the EPICS build system in the same way as our own EPICS unit testing stuff, without changes to Make rules, perl wrappers etc. Use is through its own gtest_main.cc stub that replaces the original listener with the TAP listener before running tests. Both files are under the MIT license, so they could easily be included in Base. Opinions? Cheers, ~Ralph
| ANJ, 26 Apr 2019 |
Home
News
About
Talk
Base
Modules
Extensions
