2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
From: Ralph Lange via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 02 May 2019 09:33:49 -0000
The root cause seems related to the fact that at that point the Chocolatey packagers of MinGW switched their upstream from the original MinGW project to MinGW-w64.
(see https://chocolatey.org/packages/mingw/8.1.0)
On my local machine, I cannot use Chocolatey packages (no Admin rights),
compiling on the latest direct install of MinGW-w64/MSYS2 works, but
uses different versions of things (e.g. gcc 8.3.0 for 64bit, gcc 7.4.0
for 32bit).
I will work around for the time being by explicitly using the choco
MinGW 5.3.0 version as before, and check for updates once in a while.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1827225
Title:
Status in EPICS Base:
  In Progress
Bug description:
  It looks like the epicsTempName() commit (6201d37 * 3.15) broke the
  mingw builds.
  E.g. on AppVeyor
  mingw32-make[4]: Leaving directory 'C:/projects/epics-base/modules/libcom/src/O.win32-x86-mingw'
  mingw32-make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'e_flex.exe'.  Stop.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1827225/+subscriptions
[Bug 1827225] [NEW] epicsTempName() commit breaks mingw builds Ralph Lange via Core-talk
Prev: Build completed: epics-base base-fix/appveyor-mingw-257 AppVeyor via Core-talk
Next: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) Ralph Lange via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) Ralph Lange via Core-talk
ANJ, 02 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
