2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
From: Ralph Lange via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 02 May 2019 19:35:00 -0000
Looking at the build outputs of my tests
(https://ci.appveyor.com/project/ralphlange/epics-base-5e851/history)...
The failing builds all have weird newlines in the compile commands - the
working old build doesn't. Could it be that we're hitting a line length
limit of command.com?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1827225
Title:
Status in EPICS Base:
  Fix Committed
Status in EPICS Base 3.15 series:
  Fix Committed
Status in EPICS Base 7.0 series:
  Fix Committed
Bug description:
  It looks like the epicsTempName() commit (6201d37 * 3.15) broke the
  mingw builds.
  E.g. on AppVeyor
  mingw32-make[4]: Leaving directory 'C:/projects/epics-base/modules/libcom/src/O.win32-x86-mingw'
  mingw32-make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'e_flex.exe'.  Stop.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1827225/+subscriptions
[Bug 1827225] [NEW] epicsTempName() commit breaks mingw builds Ralph Lange via Core-talk
Prev: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) Ralph Lange via Core-talk
Next: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) Ralph Lange via Core-talk
ANJ, 04 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
