2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15 #417
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 6 May 2019 10:10:35 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15/417/display/redirect>
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
No credentials specified
 > git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > git rev-parse origin/3.15^{commit} # timeout=10
Checking out Revision 16ddcaeaed34b8b306cd558ce80b5c815406d313 (origin/3.15)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 16ddcaeaed34b8b306cd558ce80b5c815406d313
Commit message: "appveyor-ci: ANL Make install 4.1 -> 4.2.1"
 > git rev-list --no-walk 63bf8a821971d83955f17e86110b88726559d10f # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
ERROR: Timeout after 10 minutes
FATAL: Command "git clean -fdx" returned status code 143:
stdout:
stderr:
hudson.plugins.git.GitException: Command "git clean -fdx" returned status code 143:
stdout:
stderr:
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2042)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2010)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2006)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1638)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1650)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:828)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at hudson.plugins.git.extensions.impl.CleanCheckout.onCheckoutCompleted(CleanCheckout.java:30)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1270)
	at hudson.scm.SCM.checkout(SCM.java:504)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1816)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:429)
[WARNINGS] Skipping publisher since build result is FAILURE
Archiving artifacts
Jenkins build is back to normal : epics-base-3.15 #418 APS Jenkins via Core-talk
Prev: Re: IPAC 19 talk and paper on EPICS for physics Mark Rivers via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-vx68 #371 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-7.0-win64-test #29 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15 #418 APS Jenkins via Core-talk
ANJ, 06 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
