Subject: |
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 |
Dirk Zimoch via Core-talk <[email protected]> |
To: |
Andrew Johnson <[email protected]> |
Date: |
Fri, 10 May 2019 19:10:36 -0000 |
> There seem to be a number of possibilities for Raspbian cross-building, the
> various answers to the stack-overflow question at
> https://stackoverflow.com/questions/19162072/how-to-install-the-raspberry-pi-
> cross-compiler-on-my-linux-host-machine show several options. The Github tool-
> chain that Dirk is using does seem to be the "official" one. A fairly
> comprehensive alternative set with more recent versions is available at
> https://github.com/abhiTronix/raspberry-pi-cross-compilers
> There is also a post on Medium at https://medium.com/@au42/the-useful-
> raspberrypi-cross-compile-guide-ea56054de187 that covers resolving library
> issues using the official tool-chain, but it's configuring application builds
> using CMAKE and I haven't looked at it in detail.
I‘ll try to support them as well. I had stopped looking for alternatives once I had a working solution.
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+merge/367256
Your team EPICS Core Developers is requested to review the proposed merge of ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0.
- Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Andrew Johnson via Core-talk
Re: [Merge] ~dirk.zimoch/epics-base:raspberryPi into epics-base:7.0 Dirk Zimoch via Core-talk
Jenkins build is still unstable: epics-7.0 » linux64 #128 APS Jenkins via Core-talk
<2019>
2025
2026
<2019>
2025
2026
