Subject: |
[Bug 1829770] [NEW] event record device support broken with constant INP |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 20 May 2019 15:59:57 -0000 |
Public bug reported:
Eric Norum reported:
------------------ 8< ---------------------
record(event, "$(P)$(R)reconn_") {
field(DTYP, "Soft Channel")
field(INP, "55")
field(TPRO, "1")
record(fanout, "$(P)$(R)reconnWFR_") {
field(SCAN, "Event")
field(EVNT, "55")
field(TPRO, "1")
When the “reconn_” record is processed, niether ”reconnWFR_” nor any
other record with that SCAN setup gets triggered. It’s not enough to set
INP=55 in the .db file, I must explicitly set VAL for it to work.
The init_record() routine in devEventSoft.c (Base-3.15 branch) doesn't
look right, I think it's missing a call to eventNameToHandle().
** Affects: epics-base
Importance: Medium
Status: Confirmed
** Affects: epics-base/3.15
Importance: Medium
Status: Confirmed
** Affects: epics-base/7.0
Importance: Medium
Status: Confirmed
** Also affects: epics-base/3.15
Importance: Undecided
Status: New
** Also affects: epics-base/7.0
Importance: Medium
Status: Confirmed
** Changed in: epics-base/3.15
Status: New => Confirmed
Importance: Undecided => Medium
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1829770
Title:
Status in EPICS Base:
Confirmed
Status in EPICS Base 3.15 series:
Confirmed
Status in EPICS Base 7.0 series:
Confirmed
Bug description:
field(INP, "55")
field(TPRO, "1")
field(EVNT, "55")
field(TPRO, "1")
set INP=55 in the .db file, I must explicitly set VAL for it to work.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1829770/+subscriptions
- [Bug 1829770] Re: event record device support broken with constant INP Andrew Johnson via Core-talk
Crash in pvData Mark Rivers via Core-talk
Re: Missing abstracts for the EPICS meeting Heinz Junkes via Core-talk
<2019>
2025
2026
RE: Crash in pvData Mark Rivers via Core-talk
<2019>
2025
2026
