2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvDatabase-win64 #632
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 21 May 2019 10:16:56 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-pvDatabase-win64/632/display/redirect?page=changes>
Changes:
[mrkraimer] updateMaster was putting to every client field instead of only changed
[mrkraimer] another fix for updateMaster nug
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-pvDatabase-win64/ws/>
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://github.com/epics-base/pvDatabaseCPP.git # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvDatabaseCPP.git
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress https://github.com/epics-base/pvDatabaseCPP.git +refs/heads/*:refs/remotes/origin/*
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/master^{commit}" # timeout=10
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/origin/master^{commit}" # timeout=10
Checking out Revision 898868d5f431d5187c19d5431858bf1fcfe5bb19 (refs/remotes/origin/master)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f 898868d5f431d5187c19d5431858bf1fcfe5bb19
Commit message: "Merge pull request #43 from mrkraimer/master"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk 2715f585e0e4bca7dae3e0ad9e25dd44278d075c # timeout=10
[epics-pvDatabase-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins5587163541027567340.bat
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>SET TA=win64
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>SET BV=7.0
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>SET CR=configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>SET WS=C:/Jenkins/win64-2/workspace
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>SET MO=-j4 -O --no-print-directory
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>echo # RELEASE for jenkins-epics-pvDatabase-win64-632 1>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>echo PVACCESS = C:/Jenkins/win64-2/workspace/epics-pvAccess-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>echo PVDATA = C:/Jenkins/win64-2/workspace/epics-pvData-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>echo EPICS_BASE = C:/Jenkins/win64-2/workspace/epics-base-7.0-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>make -j4 -O --no-print-directory
make -C ./configure install
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
Can't open perl script "C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/makeMakefile.pl": No such file or directory
make[1]: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_ARCHS:67: O.windows-x64] Error 2
make[1]: *** Waiting for unfinished jobs....
perl -CSD -MExtUtils::Command -e mkpath O.Common
make: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_DIRS:84: configure.install] Error 2
C:\jenkins\win64-2\workspace\epics-pvDatabase-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Jenkins build is back to normal : epics-pvDatabase-win64 #633 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-7.0-win64 #29 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64 #30 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-7.0-win64 #30 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-pvDatabase-win64 #633 APS Jenkins via Core-talk
ANJ, 21 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
