2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1829919] [NEW] IOC segfaults when calling dbLoadRecords after iocInit
From: Martin Konrad via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 21 May 2019 19:13:22 -0000
Public bug reported:
Diego Omitto reported the following issue:
I know that we are not supposed to load records after the iocInit but I
think it should not segFault.
$cat dummy.db
record(ai,"dummy"){}
$ softIoc
epics> iocInit
Starting iocInit
## EPICS R3.15.6-1+frib3+0~20190507132128.11+debian09~1.gbp4c10ca
## EPICS Base built May  7 2019
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 39385,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
epics> dbLoadRecords("dummy.db")
epics> #caget dummy from another terminal
epics> Segmentation fault
$ gdb /usr/lib/epics/bin/linux-x86_64-debug/softIoc
GNU gdb (Debian 7.12-6) 7.12.0.20161007-git
Copyright (C) 2016 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/lib/epics/bin/linux-x86_64-debug/softIoc...done.
(gdb) r
Starting program: /usr/lib/epics/bin/linux-x86_64-debug/softIoc
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7ffff5d51700 (LWP 6677)]
[Thread 0x7ffff5d51700 (LWP 6677) exited]
epics> iocInit
[New Thread 0x7ffff5550700 (LWP 6687)]
Starting iocInit
[New Thread 0x7ffff54cf700 (LWP 6688)]
[New Thread 0x7ffff544e700 (LWP 6689)]
[New Thread 0x7ffff5d51700 (LWP 6690)]
[New Thread 0x7ffff534d700 (LWP 6691)]
[New Thread 0x7ffff514c700 (LWP 6692)]
[New Thread 0x7ffff4f4b700 (LWP 6693)]
[New Thread 0x7ffff4d4a700 (LWP 6694)]
[New Thread 0x7ffff4b49700 (LWP 6695)]
[New Thread 0x7ffff4948700 (LWP 6696)]
[New Thread 0x7ffff4747700 (LWP 6697)]
[New Thread 0x7ffff4546700 (LWP 6698)]
[New Thread 0x7ffff4345700 (LWP 6699)]
[New Thread 0x7fffc7fff700 (LWP 6700)]
[New Thread 0x7fffc7dfe700 (LWP 6701)]
[New Thread 0x7ffff4144700 (LWP 6702)]
[New Thread 0x7fffc7bfd700 (LWP 6703)]
[New Thread 0x7fffc7afc700 (LWP 6704)]
epics> dbgf dummy
dbgf only works after iocInit
epics> [New Thread 0x7fffc7a7b700 (LWP 6913)]
[New Thread 0x7fffc797a700 (LWP 6914)]
Thread 22 "CAS-client" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffc797a700 (LWP 6914)]
dbScanLock (precord=0x5555558525f0) at ../../../src/ioc/db/dbLock.c:249
249    ../../../src/ioc/db/dbLock.c: No such file or directory.
(gdb) bt
#0  dbScanLock (precord=0x5555558525f0) at ../../../src/ioc/db/dbLock.c:249
#1  0x00007ffff7946464 in dbChannel_get_count (chan=chan@entry=0x7fffac004cb8, buffer_type=20,
    pbuffer=0x7ffff403f020, nRequest=nRequest@entry=0x7fffc7979cc0, pfl=pfl@entry=0x0)
    at ../../../src/ioc/db/db_access.c:157
#2  0x00007ffff796d29a in read_reply (pfl=0x0, eventsRemaining=1, dbch=0x7fffac004cb8, pArg=0x7fffc7979cd0)
    at ../../../src/ioc/rsrv/camessage.c:587
#3  read_notify_action (mp=<optimized out>, pPayload=<optimized out>, client=<optimized out>)
    at ../../../src/ioc/rsrv/camessage.c:804
#4  0x00007ffff796e08f in camessage (client=client@entry=0x7fffb0000f50) at ../../../src/ioc/rsrv/camessage.c:2640
#5  0x00007ffff796a981 in camsgtask (pParm=0x7fffb0000f50) at ../../../src/ioc/rsrv/camsgtask.c:117
#6  0x00007ffff76db410 in start_routine (arg=0x7fffbc0056c0) at ../../../src/libCom/osi/os/posix/osdThread.c:403
#7  0x00007ffff6b754a4 in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#8  0x00007ffff73e0d0f in clone () from /lib/x86_64-linux-gnu/libc.so.6
(gdb)
** Affects: epics-base
     Importance: Undecided
     Assignee: Martin Konrad (info-martin-konrad)
         Status: New
** Changed in: epics-base
     Assignee: (unassigned) => Martin Konrad (info-martin-konrad)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1829919
Title:
Status in EPICS Base:
  New
Bug description:
  I think it should not segFault.
  $cat dummy.db
  $ softIoc
  epics> iocInit
  Starting iocInit
  (gdb) r
  epics> iocInit
  Starting iocInit
  epics> dbgf dummy
  (gdb) bt
  (gdb)
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1829919/+subscriptions
Re: [Bug 1829919] [NEW] IOC segfaults when calling dbLoadRecords after iocInit Martin Konrad via Core-talk
Fwd: [Bug 1829919] [NEW] IOC segfaults when calling dbLoadRecords after iocInit Martin Konrad via Core-talk
[Bug 1829919] Re: IOC segfaults when calling dbLoadRecords after iocInit mdavidsaver via Core-talk
[Bug 1829919] Re: IOC segfaults when calling dbLoadRecords after iocInit Martin Konrad via Core-talk
Prev: Jenkins build is back to normal : epics-pvDatabase-win64 #633 APS Jenkins via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Bug 1829919] [NEW] IOC segfaults when calling dbLoadRecords after iocInit Martin Konrad via Core-talk
ANJ, 14 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
