2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: C++ string question
From: Mark Rivers via Core-talk <[email protected]>
Date: Fri, 31 May 2019 16:37:32 +0000
I have defined the following macro to print an error message:
#define ERR_ARGS(fmt,...) asynPrint(mSet->getUser(), ASYN_TRACE_ERROR, \
    "Param[%s]::%s: "fmt"\n", mAsynName.c_str(), functionName, __VA_ARGS__);
I call it like this:
        if(status) {
            ERR_ARGS("[param=%s] failed to create param", mAsynName.c_str());
            throw std::runtime_error(mAsynName);
So the fmt macro argument is a constant string, which is concatenated with the other constant strings in this _expression_:     "Param[%s]::%s: "fmt"\n"
This compiles fine with gcc 4.8.5 and Visual Studio 2015.
However, on gcc 7.3.0 (Ubuntu 18) I get the following error:
../GenICamFeature.cpp: In constructor ‘GenICamFeature::GenICamFeature(GenICamFeatureSet*, const string&, asynParamType, int, const string&, GCFeatureType_t)’:
../GenICamFeature.cpp:15:25: error: unable to find string literal operator ‘operator""fmt’ with ‘const char [17]’, ‘long unsigned int’ arguments
/corvette/home/epics/devel/asyn-4-35/include/asynDriver.h:272:66: note: in definition of macro ‘asynPrint’
     ? pasynTrace->printSource(pasynUser,reason,__FILE__,__LINE__,format) \
../GenICamFeature.cpp:80:13: note: in expansion of macro ‘ERR_ARGS’
Any ideas why I am getting the error and how to eliminate it?
RE: C++ string question Mark Rivers via Core-talk
Prev: Jenkins build is still unstable: epics-pva2pva-linux32 #118 APS Jenkins via Core-talk
Next: RE: C++ string question Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1830957] [NEW] pcas deadlocks in casEventSys Till Straumann via Core-talk
ANJ, 31 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
