2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1833108] [NEW] CA context not set during disconnect callback
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 17 Jun 2019 16:21:37 -0000
Public bug reported:
In thinking about https://github.com/pyepics/pyepics/issues/171 I did a
quick test of adding prints to the (dis)connection and event callbacks
in camonitor.c and find that the thread making the disconnect callback
does not (always?) have a CA context associated with it.  This means
that a disconnect callback which uses functions which implicitly pick up
the CA context (like ca_pend_io() ) can implicitly create (and leak) a
new context each time.
In my test I find that the disconnect callback is happening on a TCP
send thread.
** Affects: epics-base
     Importance: Low
         Status: New
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1833108
Title:
Status in EPICS Base:
  New
Bug description:
  a quick test of adding prints to the (dis)connection and event
  callbacks in camonitor.c and find that the thread making the
  disconnect callback does not (always?) have a CA context associated
  with it.  This means that a disconnect callback which uses functions
  which implicitly pick up the CA context (like ca_pend_io() ) can
  implicitly create (and leak) a new context each time.
  send thread.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1833108/+subscriptions
[Bug 1833108] Re: CA context not set during disconnect callback mdavidsaver via Core-talk
Prev: [Bug 608956] Re: vxWorks 6.8 deprecates the use of taskVarLib mdavidsaver via Core-talk
Next: [Bug 1833108] Re: CA context not set during disconnect callback mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 608956] Re: vxWorks 6.8 deprecates the use of taskVarLib Andrew Johnson via Core-talk
ANJ, 21 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
