2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-test #113
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 25 Jun 2019 16:10:22 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-test/113/display/redirect>
Started by upstream project "epics-base-3.15" build number 423
originally caused by:
 Started by an SCM change
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-test/ws/>
[workspace] $ /bin/sh -xe /tmp/jenkins4068904824189035667.sh
+ make -s clean-tests
../../configure/RULES_ARCHS:58: recipe for target 'clean-tests.vxWorks-ppc604_long' failed
make[2]: *** [clean-tests.vxWorks-ppc604_long] Killed
../configure/RULES_DIRS:84: recipe for target 'libCom.clean-tests' failed
make[1]: *** [libCom.clean-tests] Error 2
configure/RULES_DIRS:84: recipe for target 'src.clean-tests' failed
make: *** [src.clean-tests] Error 2
Build step 'Execute shell' marked build as failure
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: No test report files were found. Configuration error?
Jenkins build is back to normal : epics-base-3.15-test #114 APS Jenkins via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
Next: Build failed in Jenkins: epics-example-rtems #377 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~dirk.zimoch/epics-base:vxWorks5 into epics-base:7.0 Andrew Johnson via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15-test #114 APS Jenkins via Core-talk
ANJ, 25 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
