2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~info-martin-konrad/epics-base:fix-substitution-file-expansion into epics-base:3.15
From: Martin Konrad via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 26 Jun 2019 15:38:47 -0000
This one only fixes the immediate problem I ran into. https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+ref/clean-up-msi contains the same commits plus some additional clean up that should make similar problems less likely. I would recommend merging the latter.
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/361500
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
Prev: Jenkins build is still unstable: epics-7.0 » mac #132 APS Jenkins via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~info-martin-konrad/epics-base:fix-substitution-file-expansion into epics-base:3.15 Andrew Johnson via Core-talk
Next: [Merge] ~info-martin-konrad/epics-base:fix-substitution-file-expansion into epics-base:3.15 noreply--- via Core-talk
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
