2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: 3.15-pvDatabase-win64 #258
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 26 Jun 2019 18:50:19 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/3.15-pvDatabase-win64/258/display/redirect>
Started by upstream project "3.15-pvAccess-win64s" build number 279
originally caused by:
 Started by upstream project "3.15-pvAccess-win64" build number 280
  Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/3.15-pvDatabase-win64/ws/>
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://github.com/epics-base/pvDatabaseCPP.git # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvDatabaseCPP.git
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress https://github.com/epics-base/pvDatabaseCPP.git +refs/heads/*:refs/remotes/origin/*
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/master^{commit}" # timeout=10
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/origin/master^{commit}" # timeout=10
Checking out Revision 93b489252817a7500de2f71463969bf434cb0c08 (refs/remotes/origin/master)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f 93b489252817a7500de2f71463969bf434cb0c08
Commit message: "Merge pull request #48 from mrkraimer/master"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk 93b489252817a7500de2f71463969bf434cb0c08 # timeout=10
[3.15-pvDatabase-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins4143714560505716840.bat
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>SET TA=win64
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>SET BV=3.15.6
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>SET MO=-j4 -O --no-print-directory
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>SET WS=C:/Jenkins/win64-2/workspace
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>echo # RELEASE for jenkins-3.15-pvDatabase-win64-258 1>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>echo PVACCESS = C:/Jenkins/win64-2/workspace/3.15-pvAccess-win64 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>echo PVDATA = C:/Jenkins/win64-2/workspace/3.15-pvData-win64 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>echo EPICS_BASE = C:/epics/base-3.15.6 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>make -j4 -O --no-print-directory
make -C ./configure install
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/convertRelease.pl checkRelease
make -C ./src install
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m scalarAlarmSupport.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        scalarAlarmSupport.obj ../../src/support/scalarAlarmSupport.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m controlSupport.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        controlSupport.obj ../../src/support/controlSupport.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m processRecordRegister.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        processRecordRegister.obj ../../src/special/processRecordRegister.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m removeRecordRegister.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        removeRecordRegister.obj ../../src/special/removeRecordRegister.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m traceRecordRegister.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        traceRecordRegister.obj ../../src/special/traceRecordRegister.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m processRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        processRecord.obj ../../src/special/processRecord.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m removeRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        removeRecord.obj ../../src/special/removeRecord.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m traceRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        traceRecord.obj ../../src/special/traceRecord.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m registerChannelProviderLocal.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        registerChannelProviderLocal.obj ../../src/pvAccess/registerChannelProviderLocal.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m channelLocal.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        channelLocal.obj ../../src/pvAccess/channelLocal.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m monitorFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        monitorFactory.obj ../../src/pvAccess/monitorFactory.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m channelProviderLocal.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        channelProviderLocal.obj ../../src/pvAccess/channelProviderLocal.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvTimestampPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvTimestampPlugin.obj ../../src/copy/pvTimestampPlugin.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvDeadbandPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvDeadbandPlugin.obj ../../src/copy/pvDeadbandPlugin.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvDatabase.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvDatabase.obj ../../src/database/pvDatabase.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvRecord.obj ../../src/database/pvRecord.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvArrayPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvArrayPlugin.obj ../../src/copy/pvArrayPlugin.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvPlugin.obj ../../src/copy/pvPlugin.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl  -m pvCopy.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/special -I../../src/support -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include   -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include   -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include        pvCopy.obj ../../src/copy/pvCopy.cpp
mkdir ../../dbd
mkdir ../../include
mkdir ../../include/pv
make[2]: *** No rule to make target '../../lib/windows-x64/pvAccessIOC.lib', needed by 'pvDatabase.dll'.  Stop.
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [C:/epics/base-3.15.6/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make: *** [C:/epics/base-3.15.6/configure/RULES_DIRS:84: src.install] Error 2
C:\jenkins\win64-2\workspace\3.15-pvDatabase-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
Build failed in Jenkins: 3.15-pvDatabase-win64 #259 APS Jenkins via Core-talk
Build failed in Jenkins: 3.15-pvDatabase-win64 #257 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: 3.15-pvaClient-win64 #271 APS Jenkins via Core-talk
Next: Build failed in Jenkins: 3.15-pva2pva-win64 #224 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: 3.15-pvDatabase-win64 #257 APS Jenkins via Core-talk
Next: Build failed in Jenkins: 3.15-pvDatabase-win64 #259 APS Jenkins via Core-talk
ANJ, 26 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
