2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: mdavidsaver <[email protected]>
Date: Wed, 03 Jul 2019 19:08:56 -0000
> the shutdown logic changes in dbEvent.c
This is in part reverting d2b0e920012d4c9bc0eaecc0e092cedd776db578 now that a better solution is available.
> I trust you to have tested that reasonably.
Do I get some rope too?
anyway...  Your changes look fine.
I would ask that future formatt cleanup be done in a separate commit.  I note that the posix osdThread.c cleanup is going to cause conflicts if/when merging https://github.com/epics-base/epics-base/pull/24  If this was done with a separate commit, the merge process might be simplified by first reverting the cleanup.
https://code.launchpad.net/~epics-core/epics-base/+git/Com/+merge/361379
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
Next: Jenkins build is back to stable : epics-pva2pva-linux32 #122 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 23 Jul 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
