2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1840500] Re: caget and cainfo return no data for any PV when one PV in arguments does not respond
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Sat, 17 Aug 2019 15:55:39 -0000
The relevant commit is f2e54be965d14c62d879971807ee691f3a3c0c5d
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1840500
Title:
  does not respond
Status in EPICS Base:
  Confirmed
Status in EPICS Base 3.15 series:
  New
Status in EPICS Base 3.16 series:
  Won't Fix
Status in EPICS Base 7.0 series:
  Confirmed
Bug description:
  Starting with EPICS 3.15.6, also in 3.16.* and 7.*, the cainfo and
  caget tools no longer return information on any PV if one of the PVs
  in a list does not respond.  This is different from version 3.15.5 and
  earlier, in which cainfo and caget would return information on all PVs
  specified, noting those that did not respond.
  Example caget in version 3.15.5:
  $ caget Mu2e_Weather_1/temperature_degF
  Mu2e_Weather_2/temperature_degF Mu2e_Weather_1/temperature_degC
  Channel connect timed out: some PV(s) not found.
  Mu2e_Weather_1/temperature_degF 82.1742
  Mu2e_Weather_2/temperature_degF 80.615
  Mu2e_Weather_1/temperature_degC *** not connected
  Example caget in version 3.15.6:
  $ caget Mu2e_Weather_1/temperature_degF Mu2e_Weather_2/temperature_degF
  A similar difference is seen in cainfo.  In 3.15.5, it will print out info for all the specified PVs, including "never connected" status for the missing PVs.  In 3.15.6 and later, it just prints "some PV(s) not found."
  This new behavior is less useful than the original behavior.
  The cause of the change seems to be a small change in caget.c and
  cainfo.c. Here is a diff, with "<" being 3.15.5 and ">" being 3.15.6.
  544c544
  <     connect_pvs(pvs, nPvs);
  >     result = connect_pvs(pvs, nPvs);
  547,548c547,548
  <     result = caget(pvs, nPvs, request, format, type, count);
  >     if (!result)
  The identical change was made in cainfo.c.
  The original behavior was preferable, but if there is some good reason
  for not calling "caget" on PVs that failed to connect, then hopefully
  there is some way of handling that in the caget() function rather than
  just completely failing to do anything if even a single PV does not
  respond.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1840500/+subscriptions
[Bug 1840500] [NEW] caget and cainfo return no data for any PV when one PV in arguments does not respond Glenn Horton-Smith via Core-talk
Prev: [Bug 1840500] Re: caget and cainfo return no data for any PV when one PV in arguments does not respond mdavidsaver via Core-talk
Next: [Bug 1840500] Re: caget and cainfo return no data for any PV when one PV in arguments does not respond Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 19 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
