2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1841692] [NEW] Non-VME RTEMS targets should define pdevLibVME
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 27 Aug 2019 23:43:27 -0000
Public bug reported:
Support modules that build IOCs with drivers that call devLib routines
can't be compiled on non-VME RTEMS targets such as RTEMS-pc386 since the
linker fails to find the symbol pdevLibVME. The build *only* fails for
RTEMS targets though, other non-VME targets such as Windows or darwin
will quite happily compile and link the IOC code. This makes the authors
of support modules have to jump through hoops to ensure they don't build
IOCs for targets that will fail, or to just let the build fail (many
sites don't build for RTEMS anyway).
The RTEMS implementation of devLibVMEOSD.c uses pre-processor
conditionals to only define the devLibVME *pdevLibVME pointer inside
#if defined(__PPC__) || defined(__mcf528x__)
We could make life much easier for module authors by adding this:
diff --git a/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c b/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
index 0a96bad..b8f79e7 100644
--- a/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
+++ b/modules/libcom/src/osi/os/RTEMS/devLibVMEOSD.c
@@ -350,7 +350,12 @@ static void unsolicitedHandlerEPICS(int vectorNumber)
-#endif /* defined(__PPC__) && defined(mpc750) */
+#else /* !defined(__PPC__) && !defined(__mcf528x__) */
+/* No known VME interface here, provide a dummy */
+devLibVME *pdevLibVME;
+#endif /* defined(__PPC__) || defined(__mcf528x__) */
  * Some vxWorks convenience routines
With that change (which is identical to the osi/os/default version), the
non-VME RTEMS targets will build exactly the same as the workstation OS
targets; an IOC that calls devLib will now compile, although it
obviously won't actually work if booted.
Any objections?
** Affects: epics-base
     Importance: Medium
     Assignee: Andrew Johnson (anj)
         Status: In Progress
** Affects: epics-base/7.0
     Importance: Medium
         Status: In Progress
** Also affects: epics-base/7.0
   Importance: Medium
       Status: In Progress
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841692
Title:
Status in EPICS Base:
  In Progress
Status in EPICS Base 7.0 series:
  In Progress
Bug description:
  the linker fails to find the symbol pdevLibVME. The build *only* fails
  for RTEMS targets though, other non-VME targets such as Windows or
  darwin will quite happily compile and link the IOC code. This makes
  the authors of support modules have to jump through hoops to ensure
  they don't build IOCs for targets that will fail, or to just let the
  build fail (many sites don't build for RTEMS anyway).
  the non-VME RTEMS targets will build exactly the same as the
  workstation OS targets; an IOC that calls devLib will now compile,
  although it obviously won't actually work if booted.
  Any objections?
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841692/+subscriptions
[Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME mdavidsaver via Core-talk
[Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME Andrew Johnson via Core-talk
Prev: Re: Strange behavior of async calcout with CPP input link Johnson, Andrew N. via Core-talk
Next: [Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1841634] Re: CP link triggers lost when record is async mdavidsaver via Core-talk
ANJ, 01 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
