2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvPutLog?
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 30 Aug 2019 06:36:13 -0700
On 8/30/19 5:06 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> Hello,
> I think Timo's question boils down to: Does Channel Access Security work with PVA?
> And according to my quick test the answer is "No".
> So at the moment if you cannot write with caput because the access is read-only, simply use pvput and you can.
https://github.com/epics-base/pva2pva/pull/29
How can I help you, and the other core-talk subscribers reading this,
engage more with in progress development?
Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
pvPutLog? Timo Korhonen via Core-talk
Prev: Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Next: Re: pvPutLog? Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Aug 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
