2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #215
From: Jenkins EPICS PSI via Core-talk <[email protected]>
To: <[email protected]>, <[email protected]>
Date: Mon, 2 Sep 2019 22:23:49 +0200
See <http://gfa-sls2-test:8080/job/EPICS-7/215/display/redirect?page=changes>
Changes:
[ralph.lange] appveyor-ci: disable cygwin x86 builds (install is broken)
[...truncated 16.65 MB...]
/usr/bin/g++ -o softIocPVA  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64>           -rdynamic -m64         softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/softIocPVA>
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.RHEL7-x86_64'>
make -C O.RHEL7-x86_64-clang -f ../Makefile TOP=../.. \
    T_A=RHEL7-x86_64-clang install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.RHEL7-x86_64-clang'>
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_channel.d  ../pvalink_channel.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_link.d  ../pvalink_link.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_jlif.d  ../pvalink_jlif.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_lset.d  ../pvalink_lset.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink.d  ../pvalink.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF tpool.d  ../tpool.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF dbf_copy.d  ../dbf_copy.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF configparse.d  ../configparse.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbgroup.d  ../pdbgroup.cpp
clang  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF imagedemo.d  ../imagedemo.c
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF demo.d  ../demo.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbsingle.d  ../pdbsingle.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdb.d  ../pdb.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF qsrv.d  ../qsrv.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvif.d  ../pvif.cpp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/registerRecordDeviceDriver.pl>   -I. -I.. -I../O.Common -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd>    -o softIocPVA_registerRecordDeviceDriver.cpp ../O.Common/softIocPVA.dbd softIocPVA_registerRecordDeviceDriver <http://gfa-sls2-test:8080/job/EPICS-7/ws/>
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softIocPVA_registerRecordDeviceDriver.d  softIocPVA_registerRecordDeviceDriver.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softMain.d  ../softMain.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.RHEL7-x86_64-clang'>
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvif.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../qsrv.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdb.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbsingle.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../demo.cpp
clang  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../imagedemo.c
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbgroup.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../configparse.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../dbf_copy.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../tpool.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_lset.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_jlif.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_link.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_channel.cpp
/usr/bin/ar -rc    libqsrv.a    pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o
/usr/bin/ranlib libqsrv.a
clang++ -o libqsrv.so.1.1 -shared -fPIC -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang>           -rdynamic         pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl
Installing shared library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang/libqsrv.so.1.1>
ln -s libqsrv.so.1.1 <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang/libqsrv.so>
Installing library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang/libqsrv.a>
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../softMain.cpp
clang++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>    -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/clang> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c softIocPVA_registerRecordDeviceDriver.cpp
clang++ -o softIocPVA  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/RHEL7-x86_64-clang>           -rdynamic         softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64-clang/softIocPVA>
make -C O.SL6-x86_64 -f ../Makefile TOP=../.. \
    T_A=SL6-x86_64 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.SL6-x86_64'>
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_channel.d  ../pvalink_channel.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_link.d  ../pvalink_link.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_jlif.d  ../pvalink_jlif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_lset.d  ../pvalink_lset.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink.d  ../pvalink.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF tpool.d  ../tpool.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF dbf_copy.d  ../dbf_copy.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF configparse.d  ../configparse.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbgroup.d  ../pdbgroup.cpp
/usr/bin/gcc44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF imagedemo.d  ../imagedemo.c
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF demo.d  ../demo.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbsingle.d  ../pdbsingle.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdb.d  ../pdb.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF qsrv.d  ../qsrv.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvif.d  ../pvif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softIocPVA_registerRecordDeviceDriver.d  softIocPVA_registerRecordDeviceDriver.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softMain.d  ../softMain.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.SL6-x86_64'>
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../qsrv.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdb.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbsingle.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../demo.cpp
/usr/bin/gcc44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../imagedemo.c
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbgroup.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../configparse.cpp
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/anyscalar.h>: In function ‘int<unnamed>::conf_integer(void*, epics::pvData::yajl::integer_arg)’:
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/anyscalar.h>:111: warning: dereferencing pointer ‘<anonymous>’ does break strict-aliasing rules
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/anyscalar.h>:111: note: initialized from here
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../dbf_copy.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../tpool.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_lset.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_jlif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_link.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_channel.cpp
/usr/bin/g++44 -o libqsrv.so.1.1 -shared -fPIC -Wl,-hlibqsrv.so.1.1 -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64>  -L /usr/lib/x86_64-redhat-linux6E/lib64        -rdynamic -m64         pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64/libqsrv.so.1.1>
ln -s libqsrv.so.1.1 <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64/libqsrv.so>
Installing library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64/libqsrv.a>
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../softMain.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall            -m64  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c softIocPVA_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -o softIocPVA  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86_64>  -L /usr/lib/x86_64-redhat-linux6E/lib64        -rdynamic -m64         softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom    --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/SL6-x86_64/softIocPVA>
make -C O.SL6-x86 -f ../Makefile TOP=../.. \
    T_A=SL6-x86 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.SL6-x86'>
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_channel.d  ../pvalink_channel.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_link.d  ../pvalink_link.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_jlif.d  ../pvalink_jlif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_lset.d  ../pvalink_lset.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink.d  ../pvalink.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF tpool.d  ../tpool.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF dbf_copy.d  ../dbf_copy.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF configparse.d  ../configparse.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbgroup.d  ../pdbgroup.cpp
/usr/bin/gcc44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF imagedemo.d  ../imagedemo.c
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF demo.d  ../demo.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbsingle.d  ../pdbsingle.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdb.d  ../pdb.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF qsrv.d  ../qsrv.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvif.d  ../pvif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softIocPVA_registerRecordDeviceDriver.d  softIocPVA_registerRecordDeviceDriver.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softMain.d  ../softMain.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.SL6-x86'>
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../qsrv.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdb.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbsingle.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../demo.cpp
/usr/bin/gcc44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../imagedemo.c
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbgroup.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../configparse.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../dbf_copy.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../tpool.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_lset.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_jlif.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_link.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32 -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_channel.cpp
/usr/bin/g++44 -o libqsrv.so.1.1 -shared -fPIC -Wl,-hlibqsrv.so.1.1 -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86>  -L /usr/lib/x86_64-redhat-linux6E/lib         -rdynamic -m32         pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86/libqsrv.so.1.1>
ln -s libqsrv.so.1.1 <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86/libqsrv.so>
Installing library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86/libqsrv.a>
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../softMain.cpp
/usr/bin/g++44  -D_GNU_SOURCE -D_DEFAULT_SOURCE     -isystem /usr/lib/x86_64-redhat-linux6E/include  -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>   -D_X86_  -DUNIX  -Dlinux     -O3   -Wall       -march=i686      -m32  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c softIocPVA_registerRecordDeviceDriver.cpp
/usr/bin/g++44 -o softIocPVA  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/SL6-x86>  -L /usr/lib/x86_64-redhat-linux6E/lib         -rdynamic -m32         softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom    --as-needed -lc -lm -lrt -lpthread -lreadline -ltinfo
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/SL6-x86/softIocPVA>
make -C O.yocto21-aarch64 -f ../Makefile TOP=../.. \
    T_A=yocto21-aarch64 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_channel.d  ../pvalink_channel.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_link.d  ../pvalink_link.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_jlif.d  ../pvalink_jlif.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink_lset.d  ../pvalink_lset.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvalink.d  ../pvalink.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF tpool.d  ../tpool.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF dbf_copy.d  ../dbf_copy.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF configparse.d  ../configparse.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbgroup.d  ../pdbgroup.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF imagedemo.d  ../imagedemo.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF demo.d  ../demo.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdbsingle.d  ../pdbsingle.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pdb.d  ../pdb.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF qsrv.d  ../qsrv.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF pvif.d  ../pvif.cpp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/registerRecordDeviceDriver.pl>   -I. -I.. -I../O.Common -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/dbd>    -o softIocPVA_registerRecordDeviceDriver.cpp ../O.Common/softIocPVA.dbd softIocPVA_registerRecordDeviceDriver <http://gfa-sls2-test:8080/job/EPICS-7/ws/>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softIocPVA_registerRecordDeviceDriver.d  softIocPVA_registerRecordDeviceDriver.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF softMain.d  ../softMain.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvif.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../qsrv.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdb.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbsingle.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../demo.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../imagedemo.c
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pdbgroup.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../configparse.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../dbf_copy.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../tpool.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_lset.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_jlif.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_link.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall            -fPIC -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../pvalink_channel.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ar -rc    libqsrv.a    pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-ranlib libqsrv.a
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o libqsrv.so.1.1 -shared -fPIC -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64/libqsrv.so.1.1>
ln -s libqsrv.so.1.1 <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64/libqsrv.so>
Installing library <http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64/libqsrv.a>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../softMain.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3   -Wall             -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c softIocPVA_registerRecordDeviceDriver.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o softIocPVA  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Installing created executable <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/yocto21-aarch64/softIocPVA>
make -C O.V67-ppc604 -f ../Makefile TOP=../.. \
    T_A=V67-ppc604 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.V67-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvalink_channel.d  ../pvalink_channel.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvalink_link.d  ../pvalink_link.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvalink_jlif.d  ../pvalink_jlif.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvalink_lset.d  ../pvalink_lset.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvalink.d  ../pvalink.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF tpool.d  ../tpool.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF dbf_copy.d  ../dbf_copy.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF configparse.d  ../configparse.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pdbgroup.d  ../pdbgroup.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF imagedemo.d  ../imagedemo.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF demo.d  ../demo.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pdbsingle.d  ../pdbsingle.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pdb.d  ../pdb.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF qsrv.d  ../qsrv.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvif.d  ../pvif.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF softIocPVA_registerRecordDeviceDriver.d  softIocPVA_registerRecordDeviceDriver.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF softMain.d  ../softMain.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp/O.V67-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DUSE_TYPED_RSET -I../../common -I../../p2pApp -DFINAL_LOCATION="\"<http://gfa-sls2-test:8080/job/EPICS-7/ws/"";>  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../pvif.cpp
../pvif.cpp: In member function 'void ASCred::update(const boost::shared_ptr<epics::pvAccess::ChannelRequester>&)':
../pvif.cpp:96: error: no matching function for call to 'std::_Tree<std::_Tset_traits<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, false> >::iterator::iterator(std::_Tree<std::_Tset_traits<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, false> >::const_iterator)'
/afs/psi.ch/project/vxworks/WindRiverGPP3.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/../../lib/gcc/../../include/c++/4.1/xtree:371: note: candidates are: std::_Tree<_Traits>::iterator::iterator(typename _Traits::allocator_type::rebind<typename std::_Tree_nod<_Traits>::_Node>::other::pointer) [with _Traits = std::_Tset_traits<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, false>]
/afs/psi.ch/project/vxworks/WindRiverGPP3.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/../../lib/gcc/../../include/c++/4.1/xtree:356: note:                 std::_Tree<_Traits>::iterator::iterator() [with _Traits = std::_Tset_traits<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, false>]
/afs/psi.ch/project/vxworks/WindRiverGPP3.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/../../lib/gcc/../../include/c++/4.1/xtree:349: note:                 std::_Tree<std::_Tset_traits<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, false> >::iterator::iterator(const std::_Tree<std::_Tset_traits<std::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::less<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, std::allocator<std::basic_string<char, std::char_traits<char>, std::allocator<char> > >, false> >::iterator&)
make[4]: *** [pvif.o] Error 1
make[3]: *** [install.V67-ppc604] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva/pdbApp'>
make[2]: *** [pdbApp.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pva2pva'>
make[1]: *** [pva2pva.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-7 #216 Jenkins EPICS PSI via Core-talk
Prev: Build completed: EPICS Base base-3.15-424 AppVeyor via Core-talk
Next: Re: Core-talk Digest, Vol 13, Issue 213 Basawashri Biradar via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Build failed in Jenkins: EPICS-7 #216 Jenkins EPICS PSI via Core-talk
ANJ, 06 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
