Subject: |
[Bug 1844537] Re: OMSL doesn't work with constant DOL |
Ralph Lange via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Sat, 21 Sep 2019 09:31:58 -0000 |
FWIW:
Record descriptions have been converted to POD and moved into the .dbd.pod files at the recent documentathon. Those changes have been added as merge proposals, some of which might still be pending their merge.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1844537
Title:
Status in EPICS Base:
New
Bug description:
This was incorrectly documented for the boRecord. I just fixed that in
the wiki.
However, I see this as yet another arbitrary limitation.
To lift that we need a small generalisation to how we treat constant
links. A constant link just has to remember whether it has been
processed before. The flag gets set by dbGetLink and the like and it
gets reset after link initialisation (so we can change the "constant"
using a CA put to the link field). If dbGetLink finds that the link is
constant, then it converts the value from the string stored in the
link, but only if it hasn't been processed before. This also means
that we can deprecate recGblInitConstantLink because it is now
subsumed by dbGetLink.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1844537/+subscriptions
- [Bug 1844537] [NEW] OMSL doesn't work with constant DOL Ben Franksen via Core-talk
Re: EPICS 7 build failures on Appveyor/Windows Michael Davidsaver via Core-talk
Re: How to resolve git merge conflict in submodules? Zimoch Dirk (PSI) via Core-talk
<2019>
2025
2026
[Bug 1844537] Re: OMSL doesn't work with constant DOL Andrew Johnson via Core-talk
<2019>
2025
2026
