2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-7.0-win64 #53
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 24 Sep 2019 22:55:30 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/53/display/redirect>
Changes:
[...truncated 18.37 KB...]
Removing bin/windows-x64/genVersionHeader.pl
Removing bin/windows-x64/installEpics.pl
Removing bin/windows-x64/iocLogServer.exe
Removing bin/windows-x64/makeBaseApp.pl
Removing bin/windows-x64/makeBaseExt.pl
Removing bin/windows-x64/makeBpt.exe
Removing bin/windows-x64/makeIncludeDbd.pl
Removing bin/windows-x64/makeMakefile.pl
Removing bin/windows-x64/makeTestfile.pl
Removing bin/windows-x64/mkmf.pl
Removing bin/windows-x64/msi.exe
Removing bin/windows-x64/munch.pl
Removing bin/windows-x64/podRemove.pl
Removing bin/windows-x64/podToHtml.pl
Removing bin/windows-x64/pvAccessCA.dll
Removing bin/windows-x64/pvcall.exe
Removing bin/windows-x64/pvget.exe
Removing bin/windows-x64/pvinfo.exe
Removing bin/windows-x64/pvlist.exe
Removing bin/windows-x64/pvmonitor.exe
Removing bin/windows-x64/pvput.exe
Removing bin/windows-x64/registerRecordDeviceDriver.pl
Removing bin/windows-x64/replaceVAR.pl
Removing bin/windows-x64/S99caRepeater
Removing bin/windows-x64/S99logServer
Removing bin/windows-x64/softIoc.exe
Removing bin/windows-x64/tap-to-junit-xml.pl
Removing bin/windows-x64/useManifestTool.pl
Removing bin/windows-x64-static
Removing cfg/
Removing configure/O.Common/
Removing configure/O.windows-x64-static/
Removing configure/O.windows-x64/
Removing db/
Removing dbd/
Removing html/
Removing include/
Removing lib/
Removing modules/RELEASE.windows-x64-static.local
Removing modules/RELEASE.windows-x64.local
Removing modules/ca/src/client/O.Common/
Removing modules/ca/src/client/O.windows-x64-static/
Removing modules/ca/src/client/O.windows-x64/
Removing modules/ca/src/perl/O.Common/
Removing modules/ca/src/perl/O.windows-x64-static/
Removing modules/ca/src/perl/O.windows-x64/
Removing modules/ca/src/template/O.Common/
Removing modules/ca/src/template/O.windows-x64-static/
Removing modules/ca/src/template/O.windows-x64/
Removing modules/ca/src/tools/O.Common/
Removing modules/ca/src/tools/O.windows-x64-static/
Removing modules/ca/src/tools/O.windows-x64/
Removing modules/database/src/ioc/O.Common/
Removing modules/database/src/ioc/O.windows-x64-static/
Removing modules/database/src/ioc/O.windows-x64/
Removing modules/database/src/std/O.Common/
Removing modules/database/src/std/O.windows-x64-static/
Removing modules/database/src/std/O.windows-x64/
Removing modules/database/src/template/O.Common/
Removing modules/database/src/template/O.windows-x64-static/
Removing modules/database/src/template/O.windows-x64/
Removing modules/database/src/tools/O.Common/
Removing modules/database/src/tools/O.windows-x64-static/
Removing modules/database/src/tools/O.windows-x64/
Removing modules/database/test/ioc/db/O.Common/
Removing modules/database/test/ioc/db/O.windows-x64-static/
Removing modules/database/test/ioc/db/O.windows-x64/
Removing modules/database/test/ioc/dbtemplate/O.Common/
Removing modules/database/test/ioc/dbtemplate/O.windows-x64-static/
Removing modules/database/test/ioc/dbtemplate/O.windows-x64/
Removing modules/database/test/std/filters/O.Common/
Removing modules/database/test/std/filters/O.windows-x64-static/
Removing modules/database/test/std/filters/O.windows-x64/
Removing modules/database/test/std/link/O.Common/
Removing modules/database/test/std/link/O.windows-x64-static/
Removing modules/database/test/std/link/O.windows-x64/
Removing modules/database/test/std/rec/O.Common/
Removing modules/database/test/std/rec/O.windows-x64-static/
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest.d
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest.exe
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest.obj
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest.t
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest.tap
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/analogMonitorTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/arrayOpTest.d
Removing modules/database/test/std/rec/O.windows-x64/arrayOpTest.exe
Removing modules/database/test/std/rec/O.windows-x64/arrayOpTest.obj
Removing modules/database/test/std/rec/O.windows-x64/arrayOpTest.t
Removing modules/database/test/std/rec/O.windows-x64/arrayOpTest.tap
Removing modules/database/test/std/rec/O.windows-x64/asTest.d
Removing modules/database/test/std/rec/O.windows-x64/asTest.exe
Removing modules/database/test/std/rec/O.windows-x64/asTest.obj
Removing modules/database/test/std/rec/O.windows-x64/asTest.t
Removing modules/database/test/std/rec/O.windows-x64/asTest.tap
Removing modules/database/test/std/rec/O.windows-x64/asTestIoc.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/asTestIoc_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/asTestIoc_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/asTestIoc_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/asTestLib.d
Removing modules/database/test/std/rec/O.windows-x64/asTestLib.obj
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest.d
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest.exe
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest.obj
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest.t
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest.tap
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/asyncproctest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/asyncSoftTest.d
Removing modules/database/test/std/rec/O.windows-x64/asyncSoftTest.exe
Removing modules/database/test/std/rec/O.windows-x64/asyncSoftTest.obj
Removing modules/database/test/std/rec/O.windows-x64/asyncSoftTest.t
Removing modules/database/test/std/rec/O.windows-x64/asyncSoftTest.tap
Removing modules/database/test/std/rec/O.windows-x64/compressTest.d
Removing modules/database/test/std/rec/O.windows-x64/compressTest.exe
Removing modules/database/test/std/rec/O.windows-x64/compressTest.obj
Removing modules/database/test/std/rec/O.windows-x64/compressTest.t
Removing modules/database/test/std/rec/O.windows-x64/compressTest.tap
Removing modules/database/test/std/rec/O.windows-x64/dbRecStdTest.dll
Removing modules/database/test/std/rec/O.windows-x64/dbRecStdTest.exp
Removing modules/database/test/std/rec/O.windows-x64/dbRecStdTest.lib
Removing modules/database/test/std/rec/O.windows-x64/linkInitTest.d
Removing modules/database/test/std/rec/O.windows-x64/linkInitTest.exe
Removing modules/database/test/std/rec/O.windows-x64/linkInitTest.obj
Removing modules/database/test/std/rec/O.windows-x64/linkInitTest.t
Removing modules/database/test/std/rec/O.windows-x64/linkInitTest.tap
Removing modules/database/test/std/rec/O.windows-x64/linkRetargetLinkTest.d
Removing modules/database/test/std/rec/O.windows-x64/linkRetargetLinkTest.exe
Removing modules/database/test/std/rec/O.windows-x64/linkRetargetLinkTest.obj
Removing modules/database/test/std/rec/O.windows-x64/linkRetargetLinkTest.t
Removing modules/database/test/std/rec/O.windows-x64/linkRetargetLinkTest.tap
Removing modules/database/test/std/rec/O.windows-x64/Makefile
Removing modules/database/test/std/rec/O.windows-x64/mbbioDirectTest.d
Removing modules/database/test/std/rec/O.windows-x64/mbbioDirectTest.exe
Removing modules/database/test/std/rec/O.windows-x64/mbbioDirectTest.obj
Removing modules/database/test/std/rec/O.windows-x64/mbbioDirectTest.t
Removing modules/database/test/std/rec/O.windows-x64/mbbioDirectTest.tap
Removing modules/database/test/std/rec/O.windows-x64/netget.t
Removing modules/database/test/std/rec/O.windows-x64/recMiscTest.d
Removing modules/database/test/std/rec/O.windows-x64/recMiscTest.exe
Removing modules/database/test/std/rec/O.windows-x64/recMiscTest.obj
Removing modules/database/test/std/rec/O.windows-x64/recMiscTest.t
Removing modules/database/test/std/rec/O.windows-x64/recMiscTest.tap
Removing modules/database/test/std/rec/O.windows-x64/recTestIoc.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/recTestIoc_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/recTestIoc_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/recTestIoc_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/regressTest.d
Removing modules/database/test/std/rec/O.windows-x64/regressTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/regressTest.exe
Removing modules/database/test/std/rec/O.windows-x64/regressTest.obj
Removing modules/database/test/std/rec/O.windows-x64/regressTest.t
Removing modules/database/test/std/rec/O.windows-x64/regressTest.tap
Removing modules/database/test/std/rec/O.windows-x64/regressTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/regressTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/regressTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest.d
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest.exe
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest.obj
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest.t
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest.tap
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/scanEventTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/simmTest.d
Removing modules/database/test/std/rec/O.windows-x64/simmTest.db.d
Removing modules/database/test/std/rec/O.windows-x64/simmTest.dbd.d
Removing modules/database/test/std/rec/O.windows-x64/simmTest.exe
Removing modules/database/test/std/rec/O.windows-x64/simmTest.obj
Removing modules/database/test/std/rec/O.windows-x64/simmTest.t
Removing modules/database/test/std/rec/O.windows-x64/simmTest.tap
Removing modules/database/test/std/rec/O.windows-x64/simmTest_registerRecordDeviceDriver.cpp
Removing modules/database/test/std/rec/O.windows-x64/simmTest_registerRecordDeviceDriver.d
Removing modules/database/test/std/rec/O.windows-x64/simmTest_registerRecordDeviceDriver.obj
Removing modules/database/test/std/rec/O.windows-x64/softTest.d
Removing modules/database/test/std/rec/O.windows-x64/softTest.exe
Removing modules/database/test/std/rec/O.windows-x64/softTest.obj
Removing modules/database/test/std/rec/O.windows-x64/softTest.t
Removing modules/database/test/std/rec/O.windows-x64/softTest.tap
Removing modules/database/test/std/rec/O.windows-x64/testspec
Removing modules/database/test/tools/O.Common/
Removing modules/database/test/tools/O.windows-x64-static/
Removing modules/database/test/tools/O.windows-x64/
Removing modules/libcom/RTEMS/O.Common/
Removing modules/libcom/RTEMS/O.windows-x64-static/
Removing modules/libcom/RTEMS/O.windows-x64/
Removing modules/libcom/src/O.Common/
Removing modules/libcom/src/O.windows-x64-static/
Removing modules/libcom/src/O.windows-x64/
Removing modules/libcom/test/O.Common/
Removing modules/libcom/test/O.windows-x64-static/
Removing modules/libcom/test/O.windows-x64/
Removing modules/libcom/vxWorks/O.Common/
Removing modules/libcom/vxWorks/O.windows-x64-static/
Removing modules/libcom/vxWorks/O.windows-x64/
Removing src/template/base/O.Common/
Removing src/template/base/O.windows-x64-static/
Removing src/template/base/O.windows-x64/
Removing src/template/ext/O.Common/
Removing src/template/ext/O.windows-x64-static/
Removing src/template/ext/O.windows-x64/
Removing src/tools/O.Common/
Removing src/tools/O.windows-x64-static/
Removing src/tools/O.windows-x64/
Removing templates/
Removing test/tools/O.Common/
Removing test/tools/O.windows-x64-static/
Removing test/tools/O.windows-x64/
stderr: warning: failed to remove bin/windows-x64/ca.dll: Invalid argument
warning: failed to remove bin/windows-x64/caget.exe: Invalid argument
warning: failed to remove bin/windows-x64/Com.dll: Invalid argument
warning: failed to remove bin/windows-x64/dbCore.dll: Invalid argument
warning: failed to remove bin/windows-x64/dbRecStd.dll: Invalid argument
warning: failed to remove bin/windows-x64/pvAccess.dll: Invalid argument
warning: failed to remove bin/windows-x64/pvAccessIOC.dll: Invalid argument
warning: failed to remove bin/windows-x64/pvData.dll: Invalid argument
warning: failed to remove bin/windows-x64/qsrv.dll: Invalid argument
warning: failed to remove bin/windows-x64/softIocPVA.exe: Invalid argument
warning: failed to remove modules/database/test/std/rec/O.windows-x64/netget.tap: Invalid argument
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2160)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2128)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2124)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1729)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:1741)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.clean(CliGitAPIImpl.java:919)
	at hudson.plugins.git.GitAPI.clean(GitAPI.java:311)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.perform(RemoteInvocationHandler.java:929)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:903)
	at hudson.remoting.RemoteInvocationHandler$RPCRequest.call(RemoteInvocationHandler.java:855)
	at hudson.remoting.UserRequest.perform(UserRequest.java:212)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Jenkins build is back to normal : epics-base-7.0-win64 #54 APS Jenkins via Core-talk
Prev: Jenkins build is back to normal : epics-pva2pva-win64s #144 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64 #54 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-pvDatabase-win64s #663 APS Jenkins via Core-talk
ANJ, 24 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
