2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1815864] Re: Assemblies fail to work on Windows
From: Freddie Akeroyd via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 18 Oct 2019 20:34:02 -0000
Does it still fail with make 4.2.1 on Windows?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1815864
Title:
Status in EPICS Base:
  New
Bug description:
  Though being configured correctly in the Makefile, assemblies using
  the *_SNIPPETS setting fail to be generated on Windows. (VS 2017, GNU
  Make 4.1)
  Unexpected Make output:
  make[2]: *** No rule to make target 'RCS/../', needed by '../'.  Stop.
  The same Makefile on Linux works smoothly.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1815864/+subscriptions
Prev: [Merge] ~anj/epics-base/+git/base-3.15:epics-prove into epics-base:3.15 noreply--- via Core-talk
Next: Build failed: epics-base base-travis-345 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1815864] Re: Assemblies fail to work on Windows Ralph Lange via Core-talk
Next: [Bug 541330] Re: 'assert (size <= ntohs ( pMsg->m_postsize ))' failed in ..caserverio.c line 344 Andrew Johnson via Core-talk
ANJ, 19 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
