2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:appveyor_debug_builds into epics-base:7.0
From: mdavidsaver via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 24 Oct 2019 17:19:58 -0000
FYI, this MR will not be included in the forthcoming 7.0.3.1 release.  Not due to any issue with the appveyor config changes, but rather to the runtime issues (hang or crash on exit) it seemingly uncovers with the unittest suite and MSVC 2019.
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/373382
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
[Merge] ~freddie-akeroyd/epics-base:appveyor_debug_builds into epics-base:7.0 Freddie Akeroyd via Core-talk
Prev: [Bug 1815908] Re: casExpandRecvBuffer modifies the contents of the buffer mdavidsaver via Core-talk
Next: [Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~freddie-akeroyd/epics-base:appveyor_debug_builds into epics-base:7.0 Andrew Johnson via Core-talk
Next: Build failed: epics-base base-7.0-325 AppVeyor via Core-talk
ANJ, 24 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
