2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj)
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 31 Oct 2019 19:52:36 -0000
** Changed in: epics-base/3.15
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1827225
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.15 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  It looks like the epicsTempName() commit (6201d37 * 3.15) broke the
  mingw builds.
  E.g. on AppVeyor
  mingw32-make[4]: Leaving directory 'C:/projects/epics-base/modules/libcom/src/O.win32-x86-mingw'
  mingw32-make[4]: *** No rule to make target 'epicsTempFile.obj', needed by 'e_flex.exe'.  Stop.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1827225/+subscriptions
[Bug 1827225] [NEW] epicsTempName() commit breaks mingw builds Ralph Lange via Core-talk
Prev: [Bug 1756015] Re: Wrong day light saving times in CONFIG_SITE_ENV? Andrew Johnson via Core-talk
Next: [Bug 1812084] Re: Build failure on RTEMS 4.10.2 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1827225] Re: AppVeyor mingw builds broken (claiming missing epicsTempFile.obj) Ralph Lange via Core-talk
Next: Build failed: epics-base base-fix/appveyor-mingw-250 AppVeyor via Core-talk
ANJ, 31 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
