2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Bug 1839930] Re: astac segfaults if called with no user or location argument
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Fri, 01 Nov 2019 20:17:33 -0000
** Changed in: epics-base
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1839930
Title:
Status in EPICS Base:
  Fix Released
Bug description:
  Related to bug #541139
  In all EPICS versions up to 7.0.3 astac crashes the ioc when called
  with only 1 or 2 arguments.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1839930/+subscriptions
[Bug 1839930] [NEW] astac secfaults if called with no user or location argument Dirk Zimoch via Core-talk
Prev: [Bug 1844537] Re: OMSL="closed_loop" doesn't work with constant DOL Andrew Johnson via Core-talk
Next: [Bug 1841692] Re: Non-VME RTEMS targets should define pdevLibVME Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: [Bug 1839930] Re: astac segfaults if called with no user or location argument mdavidsaver via Core-talk
Next: Possible bug in pvput and mbbi records Florian Feldbauer via Core-talk
ANJ, 01 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
