2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Architecture dependent dbd files
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Mon, 4 Nov 2019 21:44:34 +0000
Hi Mark,
On 11/2/19 2:36 PM, Mark Rivers via Core-talk wrote:
One of the nice things about EPICS is the ability to build multiple architectures in the same tree.  This works well for libraries since arch is kept in its own directory.
However, it seems to have problems with dbd files.
So I had to use different names for Linux, Linux without libusb (old SUSE on Pilatus), vxWorks, and Windows.  If there are some feature I wanted to use on 64-bit Windows that was not available on 32-bit Windows I would need to create yet another dbd file name.
Can you summarize the differences between the content of those DBD files? Is it just device(), driver(), registrar(), function() and variable() entries that need to be added/removed, and what are the various different conditions you would need to be able to use to enable/disable those entries?
I would much prefer to build conditionals into the DBD file than to support multiple architecture-specific DBD files (see below for why); I think I can see a relatively straight-forward way to do that, although this would obviously only work on new EPICS releases.
This seems silly.  It seems like the right solution is to simply make dbd files be architecture-dependent, rather than a single version in O.Common.
If each target <arch> has its own set of dbd files, it would need its own copies of the generated *Record.h and menu*.h include files to match, and we would have to add new dbd/<arch> and include/arch/<arch> install directories to put them in. The build system would get a bit more complicated to support these, and builds will take a bit longer as each architecture built will have to run the conversion scripts (currently they only get run once, by the first host architecture).
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: Architecture dependent dbd files Ralph Lange via Core-talk
RE: Architecture dependent dbd files Mark Rivers via Core-talk
Prev: Re: Base 7 modules/RELEASE*.local files Johnson, Andrew N. via Core-talk
Next: Re: Circular Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Architecture dependent dbd files Jeong Han Lee via Core-talk
Next: Re: Architecture dependent dbd files Ralph Lange via Core-talk
ANJ, 05 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
