2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Beacon handling
From: Timo Korhonen via Core-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, EPICS Core Talk <[email protected]>
Date: Wed, 13 Nov 2019 14:34:38 +0000
Hi Michael,
After moving to Base 7.0.3.1 we have not seen the crashes anymore, running since 4 days as of now.
Before this update we saw these crashes several (up to 15) times a day. This looks good so far.
Thank you for the fix and pointing us to the right direction!
Timo
On 08/11/19 17:26, "Michael Davidsaver" <[email protected]> wrote:
    On 11/8/19 8:06 AM, Timo Korhonen via Core-talk wrote:
    > Colleagues,
    > We have recently been investigating reports of IOCs crashing. We are using base 7.0.3 and the problem seems to me somehow to be related to beacon handling in PVA code.
    Only in that each Beacon message contains a new Structure instance.
    > I attached a stack trace that I got from our colleagues working on an IOC, trying to integrate a CAEN power supply using StreamDevice.
    > The crash is probably not related to StreamDevice in any way; it seems only happen when we have PVA support activated.
    > Does the attached stack trace tell you anything? Can you give ideas about what to do to give better troubleshooting information?
    Looks like https://github.com/epics-base/pvDataCPP/issues/70 which may be fixed in Base 7.0.3.1
Beacon handling Timo Korhonen via Core-talk
Re: Beacon handling Michael Davidsaver via Core-talk
Prev: [Bug 1841608] Re: logClient falsely sends error logs on all connections Martin Konrad via Core-talk
Next: Re: [Merge] ~info-martin-konrad/epics-base:simplify-compiler-specific-macros into epics-base:3.15 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Beacon handling Michael Davidsaver via Core-talk
Next: epics.anl.gov off-line? Konrad, Martin via Core-talk
ANJ, 13 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
