2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~info-martin-konrad/epics-base:fix-crash-dbloadrecords-after-iocinit into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Thu, 14 Nov 2019 21:48:26 -0000
Review: Needs Fixing
One adjustment needed in dbLexRoutines.c, please move the #include "iocInit.h" below the definition of epicsExportSharedSymbols since the two object files are built into the same library. That fixes my mingw cross-build.
Builds fine on VxWorks back to 5.5.2 (which doesn't have stdbool.h but you took that out again).
https://code.launchpad.net/~info-martin-konrad/epics-base/+git/epics-base/+merge/375559
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~info-martin-konrad/epics-base:fix-crash-dbloadrecords-after-iocinit into epics-base:3.15 Martin Konrad via Core-talk
Prev: Re: Base 3.14.12.5 make uninstall not removing bin or lib Johnson, Andrew N. via Core-talk
Next: Re: no more __DATE__ Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: [Merge] ~info-martin-konrad/epics-base:fix-crash-dbloadrecords-after-iocinit into epics-base:3.15 Martin Konrad via Core-talk
Next: no more __DATE__ Michael Davidsaver via Core-talk
ANJ, 14 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
