2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-win32-test #255
From: APS Jenkins via Core-talk <[email protected]>
To: [email protected]
Date: Wed, 11 Dec 2019 08:15:17 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win32-test/255/display/redirect>
Changes:
[...truncated 2.90 KB...]
perl -CSD Menu.t -tap > Menu.tap
perl -CSD Recfield.t -tap > Recfield.tap
perl -CSD Recordtype.t -tap > Recordtype.tap
perl -CSD Registrar.t -tap > Registrar.tap
perl -CSD Snippets.t -tap > Snippets.tap
perl -CSD Variable.t -tap > Variable.tap
make[2]: Nothing to be done for 'tapfiles'.
make -C libCom/RTEMS tapfiles
make -C ca/client tapfiles
make -C O.win32-x86 -f ../Makefile TOP=../../../.. \
    T_A=win32-x86 tapfiles
make -C libCom/test tapfiles
make -C ca/client/tools tapfiles
make -C ca/legacy/gdd tapfiles
make -C ./ioc tapfiles
make -C O.win32-x86 -f ../Makefile TOP=../../../../.. \
make -C O.win32-x86 -f ../Makefile TOP=../../.. \
make -C ca/client/perl tapfiles
perl -CSD epicsUnitTestTest.t -tap > epicsUnitTestTest.tap
perl -CSD epicsTypesTest.t -tap > epicsTypesTest.tap
make -C ca/legacy/pcas tapfiles
perl -CSD epicsInlineTest.t -tap > epicsInlineTest.tap
make -C ./build tapfiles
perl -CSD epicsCalcTest.t -tap > epicsCalcTest.tap
perl -CSD epicsAlgorithmTest.t -tap > epicsAlgorithmTest.tap
make -C O.win32-x86 -f ../Makefile TOP=../../../../../.. \
perl -CSD epicsMathTest.t -tap > epicsMathTest.tap
perl -CSD epicsMMIOTest.t -tap > epicsMMIOTest.tap
make[3]: Nothing to be done for 'tapfiles'.
make -C ./example tapfiles
perl -CSD epicsEllTest.t -tap > epicsEllTest.tap
perl -CSD epicsEnvTest.t -tap > epicsEnvTest.tap
make -C ./directoryService tapfiles
perl -CSD epicsEnvUnsetTest.t -tap > epicsEnvUnsetTest.tap
perl -CSD epicsErrlogTest.t -tap > epicsErrlogTest.tap
make -C O.win32-x86 -f ../Makefile TOP=../../../../../../.. \
make[4]: Nothing to be done for 'tapfiles'.
perl -CSD epicsStdioTest.t -tap > epicsStdioTest.tap
perl -CSD epicsStdlibTest.t -tap > epicsStdlibTest.tap
perl -CSD epicsSockResolveTest.t -tap > epicsSockResolveTest.tap
make -C ca/legacy/pcas/ex tapfiles
make -C ioc/db/test tapfiles
perl -CSD epicsStringTest.t -tap > epicsStringTest.tap
make -C ioc/dbtemplate/test tapfiles
make -C ./std tapfiles
perl -CSD msi.t -tap > msi.tap
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
perl -CSD epicsTimeTest.t -tap > epicsTimeTest.tap
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
make -C std/filters/test tapfiles
perl -CSD tsTest.t -tap > tsTest.tap
logperl -CSD epicsTimeZoneTest.t -tap > epicsTimeZoneTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD epicsThreadTest.t -tap > epicsThreadTest.tap
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD arrTest.t -tap > arrTest.tap
perl -CSD epicsThreadOnceTest.t -tap > epicsThreadOnceTest.tap
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD decTest.t -tap > decTest.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD epicsThreadPriorityTest.t -tap > epicsThreadPriorityTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
make -C std/rec/test tapfiles
perl -CSD epicsThreadPrivateTest.t -tap > epicsThreadPrivateTest.tap
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD epicsThreadHooksTest.t -tap > epicsThreadHooksTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD scanEventTest.t -tap > scanEventTest.tap
Starting iocInit
perl -CSD epicsThreadPoolTest.t -tap > epicsThreadPoolTest.tap
perl -CSD regressTest.t -tap > regressTest.tap
perl -CSD epicsExitTest.t -tap > epicsExitTest.tap
perl -CSD epicsTimerTest.t -tap > epicsTimerTest.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD ringPointerTest.t -tap > ringPointerTest.tap
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD ringBytesTest.t -tap > ringBytesTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
Starting iocInit
Starting iocInit
Starting iocInit
perl -CSD epicsEventTest.t -tap > epicsEventTest.tap
perl -CSD epicsMutexTest.t -tap > epicsMutexTest.tap
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvtperl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD epicsSpinTest.t -tap > epicsSpinTest.tap
perl -CSD epicsAtomicTest.t -tap > epicsAtomicTest.tap
perl -CSD macDefExpandTest.t -tap > macDefExpandTest.tap
perl -CSD macLibTest.t -tap > macLibTest.tap
perl -CSD taskwdTest.t -tap > taskwdTest.tap
perl -CSD blockingSockTest.t -tap > blockingSockTest.tap
perl -CSD epicsMessageQueueTest.t -tap > epicsMessageQueueTest.tap
perl -CSD epicsStackTraceTest.t -tap > epicsStackTraceTest.tap
perl -CSD ipAddrToAsciiTest.t -tap > ipAddrToAsciiTest.tap
perl -CSD osiSockTest.t -tap > osiSockTest.tap
C:\jenkins\win32-2\workspace\epics-base-3.15-win32>make -C src -sk test-results
Breaktable.tap .. ok
DBD.tap ......... ok
Device.tap ...... ok
Driver.tap ...... ok
Function.tap .... ok
macLib.tap ...... ok
Menu.tap ........ ok
Recfield.tap .... ok
Recordtype.tap .. ok
Registrar.tap ... ok
Snippets.tap .... ok
Variable.tap .... ok
All tests successful.
Files=12, Tests=230,  1 wallclock secs ( 0.14 usr +  0.16 sys =  0.30 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ........... ok
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
macLibTest.tap ............... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........
not ok  5 - cb1.done
Failed 1/5 subtests
osiSockTest.tap .............. ok
Test Summary Report
ipAddrToAsciiTest.tap      (Wstat: 0 Tests: 5 Failed: 1)
  Failed test:  5
Files=39, Tests=2900,  5 wallclock secs ( 0.66 usr +  0.34 sys =  1.00 CPU)
Result: FAIL
make[2]: *** [../../../../configure/RULES_BUILD:354: test-results] Error 1
make[1]: *** [../../../configure/RULES_ARCHS:58: test-results.win32-x86] Error 2
make[1]: Target 'test-results' not remade because of errors.
make: *** [../configure/RULES_DIRS:84: libCom/test.test-results] Error 2
dbShutdownTest.tap ........... ok
dbPutLinkTest.tap ............ ok
dbLockTest.tap ............... ok
testdbConvert.tap ............ ok
callbackTest.tap ............. ok
callbackParallelTest.tap ..... ok
dbStateTest.tap .............. ok
dbCaStatsTest.tap ............ ok
scanIoTest.tap ............... ok
dbChannelTest.tap ............ ok
dbChArrTest.tap .............. ok
chfPluginTest.tap ............ ok
arrShorthandTest.tap ......... ok
recGblCheckDeadbandTest.tap .. ok
testPutGetTest.tap ........... ok
Files=15, Tests=2071,  2 wallclock secs ( 0.47 usr +  0.16 sys =  0.62 CPU)
Result: PASS
msi.tap .. ok
Files=1, Tests=12,  0 wallclock secs ( 0.11 usr +  0.03 sys =  0.14 CPU)
Result: PASS
tsTest.tap .... ok
dbndTest.tap .. ok
arrTest.tap ... ok
syncTest.tap .. ok
decTest.tap ... ok
Files=5, Tests=1809,  0 wallclock secs ( 0.31 usr +  0.08 sys =  0.39 CPU)
Result: PASS
arrayOpTest.tap ........ ok
analogMonitorTest.tap .. ok
scanEventTest.tap ...... ok
regressTest.tap ........ ok
Files=4, Tests=1924,  1 wallclock secs ( 0.36 usr +  0.08 sys =  0.44 CPU)
Result: PASS
make: Target 'test-results' not remade because of errors.
C:\jenkins\win32-2\workspace\epics-base-3.15-win32>exit 2
Build step 'Execute Windows batch command' marked build as failure
Build failed in Jenkins: epics-base-3.15-win32-test #256 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15-vx69 #411 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pvData-vx69 #285 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15-vx69 #412 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-win32-test #256 APS Jenkins via Core-talk
ANJ, 16 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
