2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Builds failing in Jenkins
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 11 Dec 2019 10:52:25 -0800
On 12/11/19 10:26 AM, Johnson, Andrew N. via Core-talk wrote:
> I think we're going to have to revert the commit 2e89a60c2dd405f from Base
I think you're making too much of this.  This sort of debris is a fact of life with CI builds.
Obviously it would be nice to work on a branch/PR/MR, though APS jenkins doesn't build these.
So there is no other way for Ralph to find out about this failure.
> since it modifies source files that get compiled with older C++ compilers on our supported platforms. The two previous commits were in the posix/epicsMath.h file which doesn't get compiled on those targets so arguably may use features that the general C++ sources can't.
Seems like a difference between libc++ implementations since similarly old RTEMS builds succeed.
Still, the fix will be the same.  Copious #ifdef
Re: Builds failing in Jenkins Johnson, Andrew N. via Core-talk
Build failed in Jenkins: epics-base-3.15-vx69 #411 APS Jenkins via Core-talk
Prev: Builds failing in Jenkins Johnson, Andrew N. via Core-talk
Next: Re: Builds failing in Jenkins Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 11 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
