2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #236
From: Jenkins EPICS PSI via Core-talk <[email protected]>
To: <[email protected]>, <[email protected]>
Date: Tue, 17 Dec 2019 21:19:26 +0100
See <http://gfa-sls2-test:8080/job/EPICS-7/236/display/redirect?page=changes>
Changes:
[ralph.lange] libcom: import some C99 math (isnan etc.) into global namespace
[ralph.lange] libcom: fix colliding isnan/isinf between C99 and C++0x for gcc-4
[ralph.lange] libcom: properly declare isnan() in C++ code
[mdavidsaver] epicsSockResolveTest add detail
[mdavidsaver] redo travis-ci with matrix
[mdavidsaver] travis-ci /etc/hosts workaround
[mdavidsaver] Revert "libcom: properly declare isnan() in C++ code"
[mdavidsaver] Revert "libcom: fix colliding isnan/isinf between C99 and C++0x for
[mdavidsaver] posix/epicsMath.h
[mdavidsaver] debug epicsTimerTest
[mdavidsaver] epicsTimerTest loosen test threshold
[mdavidsaver] minor epicsTimerTest
[...truncated 9.20 MB...]
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 test_reftrack.t test_reftrack
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testanyscalar.t testanyscalar
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testprinter.t testprinter
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testBitSetUtil.t testBitSetUtil
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testIntrospect.t testIntrospect
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testPVType.t testPVType
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testStandardField.t testStandardField
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testStandardPVField.t testStandardPVField
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testPVData.t testPVData
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testPVUnion.t testPVUnion
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testConvert.t testConvert
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testPVScalarArray.t testPVScalarArray
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testPVStructureArray.t testPVStructureArray
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testOperators.t testOperators
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testFieldBuilder.t testFieldBuilder
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testValueBuilder.t testValueBuilder
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testProperty.t testProperty
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> SL6-x86 RHEL7-x86_64 testCreateRequest.t testCreateRequest
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData/testApp/O.SL6-x86'>
make -C O.yocto21-aarch64 -f ../Makefile TOP=../.. \
    T_A=yocto21-aarch64 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData/testApp/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testCreateRequest.d  ../../testApp/copy/testCreateRequest.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testProperty.d  ../../testApp/property/testProperty.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testValueBuilder.d  ../../testApp/pv/testValueBuilder.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testFieldBuilder.d  ../../testApp/pv/testFieldBuilder.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testOperators.d  ../../testApp/pv/testOperators.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testPVStructureArray.d  ../../testApp/pv/testPVStructureArray.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testPVScalarArray.d  ../../testApp/pv/testPVScalarArray.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testConvert.d  ../../testApp/pv/testConvert.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testPVUnion.d  ../../testApp/pv/testPVUnion.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testPVData.d  ../../testApp/pv/testPVData.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testStandardPVField.d  ../../testApp/pv/testStandardPVField.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testStandardField.d  ../../testApp/pv/testStandardField.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testPVType.d  ../../testApp/pv/testPVType.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testIntrospect.d  ../../testApp/pv/testIntrospect.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testBitSetUtil.d  ../../testApp/pv/testBitSetUtil.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testprinter.d  ../../testApp/misc/testprinter.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testanyscalar.d  ../../testApp/misc/testanyscalar.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF test_reftrack.d  ../../testApp/misc/test_reftrack.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testjson.d  ../../testApp/misc/testjson.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testUnitTest.d  ../../testApp/misc/testUnitTest.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testTypeCast.d  ../../testApp/misc/testTypeCast.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testTimeStamp.d  ../../testApp/misc/testTimeStamp.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testSerialization.d  ../../testApp/misc/testSerialization.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testDebugPtr.d  ../../testApp/misc/testDebugPtr.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testSharedVector.d  ../../testApp/misc/testSharedVector.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testBaseException.d  ../../testApp/misc/testBaseException.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testByteBuffer.d  ../../testApp/misc/testByteBuffer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testByteOrder.d  ../../testApp/misc/testByteOrder.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testOverrunBitSet.d  ../../testApp/misc/testOverrunBitSet.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testBitSet.d  ../../testApp/misc/testBitSet.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testTimer.d  ../../testApp/misc/testTimer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testEvent.d  ../../testApp/misc/testEvent.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF testThread.d  ../../testApp/misc/testThread.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -MM -MF performstruct.d  ../../testApp/pv/performstruct.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData/testApp/O.yocto21-aarch64'>
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/performstruct.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o performstruct  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         performstruct.o    -lpvData -lCom  -lrt
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testThread.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testThread  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testThread.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testEvent.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testEvent  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testEvent.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testTimer.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testTimer  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testTimer.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testBitSet.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testBitSet  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testBitSet.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testOverrunBitSet.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testOverrunBitSet  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testOverrunBitSet.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testByteOrder.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testByteOrder  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testByteOrder.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testByteBuffer.cpp
In file included from <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/pvUnitTest.h>:11:0,
                 from ../../testApp/misc/testByteBuffer.cpp:19:
../../testApp/misc/testByteBuffer.cpp: In function ‘void testBasicOperations()’:
../../testApp/misc/testByteBuffer.cpp:164:36: warning: ‘const char* epics::pvData::ByteBuffer::getArray() const’ is deprecated [-Wdeprecated-declarations]
     testOk1(strncmp(buff->getArray(),&src[2],6)==0);
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/epicsUnitTest.h>:41:30: note: in definition of macro ‘testOk1’
 #define testOk1(cond) testOk(cond, "%s", #cond)
In file included from <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/pvIntrospect.h>:22:0,
                 from <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/pvData.h>:22,
                 from <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/pvUnitTest.h>:15,
<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/byteBuffer.h>:699:37: note: declared here
     EPICS_ALWAYS_INLINE const char* getArray() const EPICS_DEPRECATED
../../testApp/misc/testByteBuffer.cpp: In function ‘void testInverseEndianness(int, const char*)’:
../../testApp/misc/testByteBuffer.cpp:191:35: warning: ‘const char* epics::pvData::ByteBuffer::getArray() const’ is deprecated [-Wdeprecated-declarations]
     testOk1(strncmp(buf->getArray(),expect,6)==0);
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testByteBuffer  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testByteBuffer.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testBaseException.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testBaseException  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testBaseException.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testSharedVector.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testSharedVector  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testSharedVector.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testDebugPtr.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testDebugPtr  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testDebugPtr.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testSerialization.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testSerialization  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testSerialization.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testTimeStamp.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testTimeStamp  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testTimeStamp.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testTypeCast.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testTypeCast  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testTypeCast.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testUnitTest.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testUnitTest  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testUnitTest.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testjson.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testjson  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testjson.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/test_reftrack.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o test_reftrack  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         test_reftrack.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testanyscalar.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testanyscalar  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testanyscalar.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/misc/testprinter.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testprinter  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testprinter.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testBitSetUtil.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testBitSetUtil  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testBitSetUtil.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testIntrospect.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testIntrospect  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testIntrospect.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testPVType.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testPVType  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testPVType.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testStandardField.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testStandardField  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testStandardField.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testStandardPVField.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testStandardPVField  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testStandardPVField.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testPVData.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testPVData  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testPVData.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testPVUnion.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testPVUnion  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testPVUnion.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testConvert.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testConvert  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testConvert.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testPVScalarArray.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testPVScalarArray  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testPVScalarArray.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testPVStructureArray.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testPVStructureArray  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testPVStructureArray.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testOperators.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testOperators  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testOperators.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testFieldBuilder.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testFieldBuilder  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testFieldBuilder.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/pv/testValueBuilder.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testValueBuilder  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testValueBuilder.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/property/testProperty.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testProperty  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testProperty.o    -lpvData -lCom
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL  --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux  -DUNIX  -Dlinux     -O3 -g   -Wall             -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/Linux> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>        -c ../../testApp/copy/testCreateRequest.cpp
/opt/petalinux-gfa/2017.2/sysroots/x86_64-petalinux-linux/usr/bin/aarch64-xilinx-linux/aarch64-xilinx-linux-g++ -o testCreateRequest  -L<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64> -Wl,-rpath,<http://gfa-sls2-test:8080/job/EPICS-7/ws/lib/yocto21-aarch64>       --sysroot=/opt/petalinux-gfa/2017.2/sysroots/aarch64-xilinx-linux    -rdynamic         testCreateRequest.o    -lpvData -lCom
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testThread.t testThread
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testEvent.t testEvent
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testTimer.t testTimer
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testBitSet.t testBitSet
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testOverrunBitSet.t testOverrunBitSet
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testByteBuffer.t testByteBuffer
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testBaseException.t testBaseException
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testSharedVector.t testSharedVector
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testDebugPtr.t testDebugPtr
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testSerialization.t testSerialization
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testTimeStamp.t testTimeStamp
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testTypeCast.t testTypeCast
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testUnitTest.t testUnitTest
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testjson.t testjson
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 test_reftrack.t test_reftrack
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testanyscalar.t testanyscalar
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testprinter.t testprinter
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testBitSetUtil.t testBitSetUtil
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testIntrospect.t testIntrospect
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testPVType.t testPVType
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testStandardField.t testStandardField
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testStandardPVField.t testStandardPVField
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testPVData.t testPVData
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testPVUnion.t testPVUnion
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testConvert.t testConvert
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testPVScalarArray.t testPVScalarArray
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testPVStructureArray.t testPVStructureArray
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testOperators.t testOperators
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testFieldBuilder.t testFieldBuilder
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testValueBuilder.t testValueBuilder
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testProperty.t testProperty
perl -CSD <http://gfa-sls2-test:8080/job/EPICS-7/ws/bin/RHEL7-x86_64/makeTestfile.pl> yocto21-aarch64 RHEL7-x86_64 testCreateRequest.t testCreateRequest
make -C O.V67-ppc604 -f ../Makefile TOP=../.. \
    T_A=V67-ppc604 install
make[4]: Entering directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData/testApp/O.V67-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF pvDataAllTests.d  ../pvDataAllTests.c
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testCreateRequest.d  ../../testApp/copy/testCreateRequest.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testProperty.d  ../../testApp/property/testProperty.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testFieldBuilder.d  ../../testApp/pv/testFieldBuilder.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testOperators.d  ../../testApp/pv/testOperators.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testPVStructureArray.d  ../../testApp/pv/testPVStructureArray.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testPVScalarArray.d  ../../testApp/pv/testPVScalarArray.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testConvert.d  ../../testApp/pv/testConvert.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testPVUnion.d  ../../testApp/pv/testPVUnion.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testPVData.d  ../../testApp/pv/testPVData.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testStandardPVField.d  ../../testApp/pv/testStandardPVField.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testStandardField.d  ../../testApp/pv/testStandardField.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testPVType.d  ../../testApp/pv/testPVType.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testIntrospect.d  ../../testApp/pv/testIntrospect.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testBitSetUtil.d  ../../testApp/pv/testBitSetUtil.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testTypeCast.d  ../../testApp/misc/testTypeCast.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testTimeStamp.d  ../../testApp/misc/testTimeStamp.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testSerialization.d  ../../testApp/misc/testSerialization.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testSharedVector.d  ../../testApp/misc/testSharedVector.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testBaseException.d  ../../testApp/misc/testBaseException.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testByteBuffer.d  ../../testApp/misc/testByteBuffer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testOverrunBitSet.d  ../../testApp/misc/testOverrunBitSet.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testBitSet.d  ../../testApp/misc/testBitSet.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testTimer.d  ../../testApp/misc/testTimer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testEvent.d  ../../testApp/misc/testEvent.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -MM -MF testThread.d  ../../testApp/misc/testThread.cpp
make[4]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData/testApp/O.V67-ppc604'>
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testThread.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testEvent.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testTimer.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testBitSet.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testOverrunBitSet.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testByteBuffer.cpp
../../testApp/misc/testByteBuffer.cpp: In function 'void testBasicOperations()':
../../testApp/misc/testByteBuffer.cpp:164: warning: 'getArray' is deprecated (declared at <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/byteBuffer.h>:699)
../../testApp/misc/testByteBuffer.cpp: In function 'void testInverseEndianness(int, const char*)':
../../testApp/misc/testByteBuffer.cpp:191: warning: 'getArray' is deprecated (declared at <http://gfa-sls2-test:8080/job/EPICS-7/ws/include/pv/byteBuffer.h>:699)
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testBaseException.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testSharedVector.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testSerialization.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testTimeStamp.cpp
/afs/psi.ch/project/vxworks/VxWorks6.7/gnu/4.1.2-vxworks-6.7/x86-linux2/bin/ccppc           -DPVD_INTERNAL  -DCPU=PPC604  -DvxWorks=vxWorks -include /afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/vxWorks.h    -O2   -Wall      -mcpu=604 -mstrict-align -fno-implicit-fp -mlongcall -D_VSB_CONFIG_FILE='<../lib/h/config/vsbConfig.h>'    -fno-builtin  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/compiler/gcc> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include/os/vxWorks> -I<http://gfa-sls2-test:8080/job/EPICS-7/ws/include>       -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h -I/afs/psi.ch/project/vxworks/VxWorks6.7/vxworks-6.7/target/h/wrn/coreip -c ../../testApp/misc/testTypeCast.cpp
../../testApp/misc/testTypeCast.cpp:27: error: 'std::isnan' has not been declared
make[4]: *** [testTypeCast.o] Error 1
make[3]: *** [install.V67-ppc604] Error 2
make[3]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData/testApp'>
make[2]: *** [testApp.install] Error 2
make[2]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules/pvData'>
make[1]: *** [pvData.install] Error 2
make[1]: Leaving directory `<http://gfa-sls2-test:8080/job/EPICS-7/ws/modules'>
make: *** [modules.install] Error 2
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-7 #237 Jenkins EPICS PSI via Core-talk
Prev: Re: Build failed in Jenkins: epics-7.0 » mac #173 Michael Davidsaver via Core-talk
Next: [Merge] ~info-martin-konrad/epics-base:fix-typos into epics-base:3.15 Martin Konrad via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Build failed: EPICS Base base-7.0-492 AppVeyor via Core-talk
Next: Build failed in Jenkins: EPICS-7 #237 Jenkins EPICS PSI via Core-talk
ANJ, 19 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
