Thanks Dirk,
I will test this solution
Best Regards
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1829770
Title:
event record device support broken with constant INP
Status in EPICS Base:
Confirmed
Status in EPICS Base 3.15 series:
Confirmed
Status in EPICS Base 7.0 series:
Confirmed
Bug description:
Eric Norum reported:
------------------ 8< ---------------------
record(event, "$(P)$(R)reconn_") {
field(DTYP, "Soft Channel")
field(INP, "55")
field(TPRO, "1")
record(fanout, "$(P)$(R)reconnWFR_") {
field(SCAN, "Event")
field(EVNT, "55")
field(TPRO, "1")
When the “reconn_” record is processed, niether ”reconnWFR_” nor any
other record with that SCAN setup gets triggered. It’s not enough to
set INP=55 in the .db file, I must explicitly set VAL for it to work.
The init_record() routine in devEventSoft.c (Base-3.15 branch) doesn't
look right, I think it's missing a call to eventNameToHandle().
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1829770/+subscriptions
Jenkins build is back to normal : epics-base-7.0-win64 #88 APS Jenkins via Core-talk
[Bug 1829770] Re: event record device support broken with constant INP Gabriel Fedel via Core-talk
<2020>
2025
2026
[Bug 1829770] Re: event record device support broken with constant INP Dirk Zimoch via Core-talk
<2020>
2025
2026
