2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: [Bug 1862916] Re: Possible null pointer dereferencing in modules/ca/src/client/udpiiu.cpp
From: Karl Vestin via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 13 Feb 2020 10:44:50 -0000
** Changed in: epics-base
     Assignee: (unassigned) => Karl Vestin (karlvestin)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1862916
Title:
Status in EPICS Base:
  New
Bug description:
  Codacy report an Error level issue on a possible null pointer
  dereferencing  modules/ca/src/client/udpiiu.cpp line 950.
  If the function bool udpiiu::pushDatagramMsg ( epicsGuard < epicsMutex > & guard, const caHdr & msg, const void * pExt, ca_uint16_t extsize ) is called with the following parameters:
  1) pExt == null
  2) extsize > 0
  This will cause the memcpy to read extsize bytes from null, presumably
  crashing the code.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1862916/+subscriptions
[Bug 1862916] [NEW] Possible null pointer dereferencing in modules/ca/src/client/udpiiu.cpp Karl Vestin via Core-talk
Prev: [Bug 1862918] Re: Uninitialized struct member: probe.sevr in modules/database/src/ioc/db/dbChannel.c Karl Vestin via Core-talk
Next: [Bug 1862917] Re: Possible memory leak in modules/database/src/std/link/lnkCalc.c Karl Vestin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: [Bug 1862916] Re: Possible null pointer dereferencing in modules/ca/src/client/udpiiu.cpp mdavidsaver via Core-talk
Next: [Bug 1862916] Re: Possible null pointer dereferencing in modules/ca/src/client/udpiiu.cpp Karl Vestin via Core-talk
ANJ, 13 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
