2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 772471] Re: handle leak, win32 port
From: Freddie Akeroyd via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 14 Feb 2020 00:46:11 -0000
I think this could be the same issue referred to at
https://epics.anl.gov/tech-talk/2013/msg00857.php - in which case it is
now fixed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/772471
Title:
Status in EPICS Base:
  New
Bug description:
  From Carsten Winkler,
  It seems to be a handle leak in Channel Access Server V4.13 (current
  EPICS base)
  Create any PVs at softIoc, request it via caget and you see the handle count at softIoc will be
  increased by two and won't be freed anymore (without using any EPICS gateway).
  If you frequently repeat this procedure you will end up to in a "WINSOCK Error 10055".
  This problem occurs at Windows XP with patched EPICS bas 3.14.12.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/772471/+subscriptions
Prev: Build failed: EPICS Base base-7.0-534 AppVeyor via Core-talk
Next: [Bug 1838792] Re: epicsCalc bit-wise operators on aarch64 Launchpad Bug Tracker via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 13 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
