2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-7.0-win64 #97
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 15 Feb 2020 04:55:11 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/97/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64/ws/>
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Using shallow fetch with depth 5
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress --depth=5 -- https://git.launchpad.net/epics-base +refs/heads/7.0:refs/remotes/origin/7.0 # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:899)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1114)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1145)
	at hudson.scm.SCM.checkout(SCM.java:505)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1205)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1853)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:427)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe fetch --no-tags --force --progress --depth=5 -- https://git.launchpad.net/epics-base +refs/heads/7.0:refs/remotes/origin/7.0" returned status code 128:
stdout:
stderr: fatal: Couldn't find remote ref refs/heads/7.0
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2372)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1985)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:80)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:563)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:161)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:154)
	at hudson.remoting.UserRequest.perform(UserRequest.java:211)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:369)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-2
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
		at hudson.remoting.Channel.call(Channel.java:955)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
		at sun.reflect.GeneratedMethodAccessor947.invoke(Unknown Source)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
		at com.sun.proxy.$Proxy106.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:897)
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Jenkins build is back to normal : epics-base-7.0-win64 #98 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-7.0-win64 #96 APS Jenkins via Core-talk
Prev: Jenkins build is back to stable : epics-base-3.15-win32s-test #276 APS Jenkins via Core-talk
Next: Jenkins build became unstable: epics-7.0 » linux32 #200 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-7.0-win64 #96 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-7.0-win64 #98 APS Jenkins via Core-talk
ANJ, 15 Feb 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
