2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~freddie-akeroyd/epics-base:bit_operations into epics-base:3.15
From: Freddie Akeroyd via Core-talk <core-talk at aps.anl.gov>
To: mp+379191 at code.launchpad.net
Date: Mon, 17 Feb 2020 17:12:43 -0000
Thanks for checking on ARMv7 Martin.
I found I have now needed to disable some unrelated x64 maths checks on x86 too for all the other tests to pass on win32. The only issue I haven't addressed yet is hard tabs - the lines I added currently have hard tab that match the rest of the file, I just wanted to check whether I should convert the entire file from tabs -> space?
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/379191
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~freddie-akeroyd/epics-base:bit_operations into epics-base:3.15 Freddie Akeroyd via Core-talk
Prev: Re: [Merge] ~dirk.zimoch/epics-base:dbChannelForDBLinks into epics-base:7.0 Dirk Zimoch via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:fix_osdsockaddrreuse_on_win32 into epics-base:7.0 Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~freddie-akeroyd/epics-base:bit_operations into epics-base:3.15 Martin Konrad via Core-talk
Next: Re: [Merge] ~freddie-akeroyd/epics-base:bit_operations into epics-base:3.15 Freddie Akeroyd via Core-talk
ANJ, 09 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
