See <https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/203/display/redirect>
Changes:
Started by upstream project "epics-7.0" build number 203
originally caused by:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace <https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/ws/>
No credentials specified
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base/
> git init <https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
> git --version # timeout=10
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10
> git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Checking out Revision 90c0f5c48d133cfd0b394cd724eddbca6ff41a1b (refs/remotes/origin/7.0)
> git config core.sparsecheckout # timeout=10
> git checkout -f 90c0f5c48d133cfd0b394cd724eddbca6ff41a1b # timeout=10
FATAL: Could not checkout 90c0f5c48d133cfd0b394cd724eddbca6ff41a1b
hudson.plugins.git.GitException: Command "git checkout -f 90c0f5c48d133cfd0b394cd724eddbca6ff41a1b" returned status code 128:
stdout:
stderr: fatal: reference is not a tree: 90c0f5c48d133cfd0b394cd724eddbca6ff41a1b
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2372)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$1000(CliGitAPIImpl.java:80)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$9.execute(CliGitAPIImpl.java:2681)
Also: hudson.remoting.Channel$CallSiteStackTrace: Remote call to mac-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1741)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
at hudson.remoting.Channel.call(Channel.java:955)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:146)
at sun.reflect.GeneratedMethodAccessor947.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:132)
at com.sun.proxy.$Proxy107.execute(Unknown Source)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1195)
at hudson.scm.SCM.checkout(SCM.java:505)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1205)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
at hudson.model.Run.execute(Run.java:1853)
at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
at hudson.model.ResourceController.execute(ResourceController.java:97)
at hudson.model.Executor.run(Executor.java:427)
Caused: hudson.plugins.git.GitException: Could not checkout 90c0f5c48d133cfd0b394cd724eddbca6ff41a1b
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$9.execute(CliGitAPIImpl.java:2705)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:161)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:154)
at hudson.remoting.UserRequest.perform(UserRequest.java:211)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
- Jenkins build is back to normal : epics-7.0 » mac #204 APS Jenkins via Core-talk
Build failed: epics-base base-allocators-4 AppVeyor via Core-talk
Build failed in Jenkins: epics-7.0 » linux32 #203 APS Jenkins via Core-talk
<2020>
2025
2026
<2020>
2025
2026
