See <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/147/display/redirect>
Changes:
[...truncated 10.26 KB...]
make -C ./src tapfiles
make -C ./client tapfiles
make -C ./template tapfiles
make -C O.windows-x64 -f ../Makefile TOP=../../../../.. \
T_A=windows-x64 tapfiles
make[5]: Nothing to be done for 'tapfiles'.
make -C ./tools tapfiles
make -C ./perl tapfiles
make -C ./database tapfiles
make -C ./ioc tapfiles
perl -CSD <https://jenkins.aps.anl.gov/job/epics-base-7.0-win64-test/ws/bin/windows-x64/genVersionHeader.pl> -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
Keeping VCS header ../O.Common/epicsVCS.h
EPICS_VCS_VERSION = "0f35d0c3f9d5e2c68655"
make -C ./std tapfiles
make -C ./test tapfiles
make -C ioc/db tapfiles
make -C ioc/dbtemplate tapfiles
make -C std/rec tapfiles
make -C std/link tapfiles
make -C O.windows-x64 -f ../Makefile TOP=../../../../../.. \
perl -CSD msi.t -tap > msi.tap
perl -CSD lnkStateTest.t -tap > lnkStateTest.tap
perl -CSD arrayOpTest.t -tap > arrayOpTest.tap
perl -CSD dbScanTest.t -tap > dbScanTest.tap
make -C std/filters tapfiles
perl -CSD lnkCalcTest.t -tap > lnkCalcTest.tap
perl -CSD recMiscTest.t -tap > recMiscTest.tap
perl -CSD linkRetargetLinkTest.t -tap > linkRetargetLinkTest.tap
perl -CSD dbShutdownTest.t -tap > dbShutdownTest.tap
perl -CSD tsTest.t -tap > tsTest.tap
perl -CSD dbndTest.t -tap > dbndTest.tap
perl -CSD Base.t -tap > Base.tap
perl -CSD arrTest.t -tap > arrTest.tap
perl -CSD Breaktable.t -tap > Breaktable.tap
perl -CSD DBD.t -tap > DBD.tap
perl -CSD syncTest.t -tap > syncTest.tap
perl -CSD Device.t -tap > Device.tap
perl -CSD linkInitTest.t -tap > linkInitTest.tap
perl -CSD Driver.t -tap > Driver.tap
perl -CSD decTest.t -tap > decTest.tap
perl -CSD Function.t -tap > Function.tap
perl -CSD dbPutLinkTest.t -tap > dbPutLinkTest.tap
dbJLinkInit: lexical error: invalid char in json text.
{"x":bbbb}
(right here) ------^
dbJLinkInit: parse error: premature EOF
{"z":{"good":6}
perl -CSD Menu.t -tap > Menu.tap
perl -CSD compressTest.t -tap > compressTest.tap
perl -CSD Recfield.t -tap > Recfield.tap
perl -CSD asyncSoftTest.t -tap > asyncSoftTest.tap
perl -CSD Recordtype.t -tap > Recordtype.tap
perl -CSD Registrar.t -tap > Registrar.tap
perl -CSD dbLockTest.t -tap > dbLockTest.tap
perl -CSD Variable.t -tap > Variable.tap
perl -CSD softTest.t -tap > softTest.tap
perl -CSD testdbConvert.t -tap > testdbConvert.tap
perl -CSD seqTest.t -tap > seqTest.tap
perl -CSD asTest.t -tap > asTest.tap
perl -CSD analogMonitorTest.t -tap > analogMonitorTest.tap
Starting iocInit
perl -CSD scanEventTest.t -tap > scanEventTest.tap
Starting iocInit
perl -CSD regressTest.t -tap > regressTest.tap
dbConvertJSON: parse error: trailing garbage
0x10
0x10
0x10
0x10
0x10
0x10
0x10
0x10
perl -CSD simmTest.t -tap > simmTest.tap
perl -CSD mbbioDirectTest.t -tap > mbbioDirectTest.tap
perl -CSD asyncproctest.t -tap > asyncproctest.tap
Starting iocInit
perl -CSD netget.t -tap > netget.tap
perl -CSD dbStateTest.t -tap > dbStateTest.tap
perl -CSD dbStressTest.t -tap > dbStressTest.tap
perl -CSD dbServerTest.t -tap > dbServerTest.tap
dbRegisterServer: Can't redefine 'one'.
dbRegisterServer: Bad server name 'bad name'
dbRegisterServer: Ignoring 'disabled', per environment
dbUnregisterServer: Servers still active!
dbUnregisterServer: 'toolate' not registered.
dbUnregisterServer: 'no-routines' has no stop() method.
perl -CSD dbCaStatsTest.t -tap > dbCaStatsTest.tap
perl -CSD callbackTest.t -tap > callbackTest.tap
perl -CSD dbChannelTest.t -tap > dbChannelTest.tap
perl -CSD callbackParallelTest.t -tap > callbackParallelTest.tap
perl -CSD chfPluginTest.t -tap > chfPluginTest.tap
chfConfigParseStart: plugin pvt alloc failed
perl -CSD dbChArrTest.t -tap > dbChArrTest.tap
Starting iocInit
perl -CSD recGblCheckDeadbandTest.t -tap > recGblCheckDeadbandTest.tap
perl -CSD arrShorthandTest.t -tap > arrShorthandTest.tap
perl -CSD testPutGetTest.t -tap > testPutGetTest.tap
perl -CSD dbStaticTest.t -tap > dbStaticTest.tap
perl -CSD dbCaLinkTest.t -tap > dbCaLinkTest.tap
perl -CSD scanIoTest.t -tap > scanIoTest.tap
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>REM Show test results. Failures should mark the job as unstable.
C:\jenkins\win64-2\workspace\epics-base-7.0-win64>make -sk test-results || exit /B 255
Snippets.tap .. ok
All tests successful.
Files=1, Tests=29, 0 wallclock secs ( 0.11 usr + 0.02 sys = 0.13 CPU)
Result: PASS
epicsUnitTestTest.tap ........ ok
epicsTypesTest.tap ........... ok
epicsInlineTest.tap .......... ok
epicsCalcTest.tap ............ ok
epicsAlgorithmTest.tap ....... ok
epicsMathTest.tap ............ ok
epicsMMIOTest.tap ............ ok
epicsEllTest.tap ............. ok
epicsEnvTest.tap ............. ok
epicsEnvUnsetTest.tap ........ ok
epicsErrlogTest.tap .......... ok
epicsStdioTest.tap ........... ok
epicsStdlibTest.tap .......... ok
epicsSockResolveTest.tap ..... ok
epicsStringTest.tap .......... ok
epicsTimeTest.tap ............ ok
epicsTimeZoneTest.tap ........ ok
epicsThreadTest.tap .......... ok
epicsThreadOnceTest.tap ...... ok
epicsThreadPriorityTest.tap .. ok
epicsThreadPrivateTest.tap ... ok
epicsThreadHooksTest.tap ..... ok
epicsThreadPoolTest.tap ...... ok
epicsExitTest.tap ............ ok
epicsTimerTest.tap ........... ok
ringPointerTest.tap .......... ok
ringBytesTest.tap ............ ok
epicsEventTest.tap ...........
not ok 18 - epicsEventWaitWithTimeout(0.031250) delay error -0.000250 sec
not ok 21 - epicsEventWaitWithTimeout(0.003906) delay error -0.003906 sec
not ok 23 - epicsEventWaitWithTimeout(0.000977) delay error -0.000977 sec
not ok 24 - epicsEventWaitWithTimeout(0.000488) delay error -0.000488 sec
not ok 25 - epicsEventWaitWithTimeout(0.000244) delay error -0.000244 sec
not ok 26 - epicsEventWaitWithTimeout(0.000122) delay error -0.000122 sec
not ok 27 - epicsEventWaitWithTimeout(0.000061) delay error -0.000061 sec
not ok 28 - epicsEventWaitWithTimeout(0.000031) delay error -0.000031 sec
not ok 29 - epicsEventWaitWithTimeout(0.000015) delay error -0.000015 sec
not ok 30 - epicsEventWaitWithTimeout(0.000008) delay error -0.000008 sec
not ok 31 - epicsEventWaitWithTimeout(0.000004) delay error -0.000004 sec
Failed 11/37 subtests
epicsMutexTest.tap ........... ok
epicsSpinTest.tap ............ ok
epicsAtomicTest.tap .......... ok
macDefExpandTest.tap ......... ok
cvtFastTest.tap .............. ok
macLibTest.tap ............... ok
aslibtest.tap ................ ok
macLib.tap ................... ok
taskwdTest.tap ............... ok
blockingSockTest.tap ......... ok
epicsMessageQueueTest.tap .... ok
epicsStackTraceTest.tap ...... ok
ipAddrToAsciiTest.tap ........ ok
osiSockTest.tap .............. ok
testexecname.tap ............. ok
iocshTest.tap ................ ok
Test Summary Report
epicsMathTest.tap (Wstat: 0 Tests: 35 Failed: 0)
TODO passed: 8-9, 11-12, 22-23
epicsEventTest.tap (Wstat: 0 Tests: 37 Failed: 11)
Failed tests: 18, 21, 23-31
Files=44, Tests=4163, 5 wallclock secs ( 0.86 usr + 0.47 sys = 1.33 CPU)
Result: FAIL
make[4]: *** [../../../../configure/RULES_BUILD:373: test-results] Error 1
make[3]: *** [../../../configure/RULES_ARCHS:58: test-results.windows-x64] Error 2
make[3]: Target 'test-results' not remade because of errors.
make[2]: *** [../../configure/RULES_DIRS:84: test.test-results] Error 2
make[2]: Target 'test-results' not remade because of errors.
make[1]: *** [../configure/RULES_DIRS:84: libcom.test-results] Error 2
make[1]: Target 'test-results' not remade because of errors.
make: *** [configure/RULES_DIRS:84: modules.test-results] Error 2
make: Target 'test-results' not remade because of errors.
Build step 'Execute Windows batch command' marked build as failure
- Timeouts returning early, was: Build failed in Jenkins Johnson, Andrew N. via Core-talk
- Build failed in Jenkins: epics-base-7.0-win64-test #148 APS Jenkins via Core-talk
Build failed: epics-base base-7.0-427 AppVeyor via Core-talk
Jenkins build became unstable: epics-base-7.0-win64s-test #143 APS Jenkins via Core-talk
<2020>
2025
2026
<2020>
2025
2026
