2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: Re: IOC build fails after removing an iocBoot dir from Git
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: "Konrad, Martin" <konrad at frib.msu.edu>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Thu, 19 Mar 2020 15:38:15 +0000
On Mar 19, 2020, at 9:08 AM, Konrad, Martin <konrad at frib.msu.edu> wrote:
Wouldn’t it be easier to just do a ‘make -C iocBoot clean’ before you
do the ‘git pull’?
I'm a bit reluctant to run make clean if not needed since this wipes out
files in the $(TOP)/bin $(TOP)/db and $(TOP)/lib folders. What if the
build fails and my IOC crashes before the IOC engineer has resolved the
problem? I have to admit that this is kind of a weak argument but just
running "make" seems to be the safest approach until we can transition
to containers…
The ‘make -C <directory> clean’ option does a clean in iocBoot and its subdirectories only. If you know which IOC has been deleted you could do ‘make -C <iocBoot/iocxxx clean’ which would only clean up that directory and wouldn’t affect any other IOCs. As Michael just posted, I didn’t say ‘make distclean’, and even doing a ‘make clean’ from the top wouldn’t delete your install directories (bin, lib, did, db etc.) although it does remove generated files from the iocBoot directories; that’s inconsistent though and we should probably fix it.
- Andrew
Complexity comes for free, simplicity you have to work for.
IOC build fails after removing an iocBoot dir from Git Konrad, Martin via Core-talk
Prev: Re: IOC build fails after removing an iocBoot dir from Git Michael Davidsaver via Core-talk
Next: Re: IOC build fails after removing an iocBoot dir from Git Konrad, Martin via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 19 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
