2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
Subject: [Bug 1868486] Re: epicsMessageQueue lost messages
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 22 Mar 2020 17:23:49 -0000
This issue has been present in all versions of epicsMessageQueue.
I see two fixes which could combine to address this issue in myReceive().
Similar changes will likely be required in mySend() as it also supports timeout.
1. Return success in threadNode.eventSent regardless of timeout status.
2. Handle the case where getEventNode() returns an epicsEvent which
   has already been triggered.  Maybe getEventNode() calls epicsEventTryWait() ?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1868486
Title:
Status in EPICS Base:
  Confirmed
Bug description:
  https://epics.anl.gov/core-talk/2020/msg00396.php
  Mark Rivers observed epicsMessageQueue losing messages.
  https://epics.anl.gov/core-talk/2020/msg00408.php
  > I think I see the logic error in how the eventSent flag is handled,
  > specifically related to the fact that epicsEvent is a semaphore as
  > opposed to a condition variable.
  > This allows a "race" to occur if the first/only waiting receiver
  > times out, and epicsEventWaitWithTimeout() returns, while a sender
  > is in epicsMessageQueueSend() preparing to wake up a receiver.
  > This results in a situation where the sender has set the eventSent,
  > and indeed copied a message to the buffer of, a thread which has
  > decided to abort.
  > After timing out, the receiver sees the timeout and returns -1
  > even through eventSent has been set.  This can be trapped with:
  > > b osdMessageQueue.cpp:358 if status!=0 && threadNode.eventSent
  > So here is your lost message.
  > Now when epicsMessageQueueReceiveWithTimeout() is called again, no message
  > is waiting in the queue, so epicsEventWaitWithTimeout() is called.
  > Since the semaphore is already set, this returns immediately with status==0,
  > but this is a spurious wakeup and the eventSent flag is not set.
  > And here is the second "timeout".
  Line numbers circa 7.0.3.1
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1868486/+subscriptions
[Bug 1868486] [NEW] epicsMessageQueue lost messages mdavidsaver via Core-talk
Prev: [Bug 1868486] [NEW] epicsMessageQueue lost messages mdavidsaver via Core-talk
Next: [Bug 1868486] Re: epicsMessageQueue lost messages mdavidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <2020>  2021  2022  2023  2024  2025  2026
ANJ, 22 Mar 2020 · Home · News · About · Talk · Base · Modules · Extensions ·
