Am 30.03.20 um 15:21 schrieb Ben Franksen via Core-talk:
> Indeed, DB links have always supported a limited form
> of meta data transfer even for put, via the MS flag. Perhaps it will
> turn out that this can be generalized using put filters?
One useful application could be a filter that extends/replaces the MS
flag behavior for links in such a way that the record that receives the
data also inherits the status (in case the severity of the source is
higher than the current one in the target). Think of a calc record with
two input links that point to hardware records. If the operator could
directly read off the inherited status, it may be more obvious where the
problem actually comes from than with the current status LINK. Such a
filter would be useful for both input and output links, BTW.
Cheers
Ben
...it is impossible to speak of a depoliticized economy as the liberals
do, or of a separation between economic exploitation and political
oppression as the Marxists articulate. The basic distinction, rather, is
between power and creativity...
-- Jonathan Nitzan and Shimshon Bichler: Capital as Power
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
pEpkey.asc
Description: application/pgp-keys
- double filters Ben Franksen via Core-talk
- Re: double filters Johnson, Andrew N. via Core-talk
- Re: double filters Ben Franksen via Core-talk
- Re: double filters Ralph Lange via Core-talk
Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 Ben Franksen via Core-talk
Re: [Merge] ~bfrk/epics-base:zero-size-array-request into epics-base:7.0 mdavidsaver via Core-talk
<2020>
2025
2026
<2020>
2025
2026
